i am planning on using my '89 1.4 340 to learn to drift in, and would like some help getting my basic drift setup started...
i already have a welded and plated diff, 2 coils off the front and 3 inch lowering blocks on the rear, as well as stripped out the rear and 2 bucket seats and harnesses...
however, i have heard you can change the oil in the front shocks to stiffen them up, is this possible? if so, what will i need?
also, what is needed to swap for the land rover shocks on the rear?
are there any upgraded clutches available for these, or would i be able to use something a bit more heavy duty from another model, etc?
what else would i need? many thanks!!!
