As finding front konis to the 340 is almost impossible, does anyone know of some other model that front suspension can be adapted in the 340?
I have konis in the rear now I need them to the front
Thanks in advance
Front konis... from what model?
Units are metric (mm)
http://www.janiervast.com/kuvat/iskarit ... 0_ver2.jpg
More stuff:
http://www.janiervast.com/kuvat/index.php?dir=iskarit/
On that one pic with finnish text measures are Length and then diameter on same line for each section.
Don't know if helps to find anything, but now you at least know what size to look for
More stuff:
I have spent a lot of time looking for possible dampers to fit but there is nothing. That is why I went the mono tube path.
