germ
Post
by germ » 15 Apr 2007 11:21 am
it burbles nicely
deep loud popping on deceration which can also be loud somone said its like a rally car xD
my camera can give any impression on sound at all
1 other thing it sounds even nicer when moving
no one try to over take me ever
ohh and they dont get too close to me at the back which is also nice
Volvo 340
1988
IvanS.
Post
by IvanS. » 18 Apr 2007 08:41 pm
^^^^ if they do, hit em with a bit of high rpm and the result would be devastating ( from the sound of the exhaust )
BTW looks nice....like remus.
Volvo 340 GL 1.4 (1986)
Ali
Post
by Ali » 18 Apr 2007 09:12 pm
Lol welcome to the exhaust facing into the middle of the car group
I think everyone thats tried changing a 300 exhaust has had that problem, its a bugger to get it coming out straight without changing more of the system
germ
Post
by germ » 18 Apr 2007 09:16 pm
yup it is indeed. i changed the whole system but same layout bigger pipes
wanted it right down the middle but well we cant have every thing
ohh i changed cam belt today :S what a job :S and lost a bit of my drill bit in the engine got some out but not all....car runs fine some how...me thinks its in the sump.
Cheers will
Volvo 340
1988
A M R
Post
by A M R » 20 Apr 2007 07:26 pm
hi im back! tinternet died for a couple of weeks there
anyway, i saw this post and reminded me of something i wanted to get:
http://cgi.ebay.co.uk/NEWTWIN3inch-ALLO ... dZViewItem
i think it would go quite nicely. paint it black or leave it as it is?
also why does the exhaust point towards the middle? can this be sorted easily or with a bit of bodging? ali how did you get yours to come out straight?
cheers. (sorry for threadjack)
germ
Post
by germ » 20 Apr 2007 09:05 pm
well i put mine over axal like original pipe right from downpipe down and used exact same layout of exhaust with bigger pipe.
but it still came out at a angle
the pipe just goes that way i could of done somthing about it i guess but i wanted to do it quick with out welding ,and also didnt want to make a mess with gungum etc
hijacking acorded AMR
will
Volvo 340
1988
Post
by 340GLT » 20 Apr 2007 11:26 pm
I never had a problem making mine come out straight and its straight on both sides!!! lol
Just a small question why the hell is that box made from aluminium???
A M R
Post
by A M R » 20 Apr 2007 11:39 pm
what that ebay one? how do you know if its aluminium? and whats wrong with aluminium?
Post
by jtbo » 21 Apr 2007 07:11 am
A M R wrote:what that ebay one? how do you know if its aluminium? and whats wrong with aluminium?
It says Alloy in URL
I have found out that nobody likes to drive behind of my car either, at least when uphill comes they like to leave some space as exhaust is not most quiet, also with K-cam exhaust pulses are much stronger making lot more noise.
When I drive 300km my ears ring whole evening, bit too loud for street use.
Citroen ZX Dturbo -97 -daily-
stealthstylz
Post
by stealthstylz » 21 Apr 2007 08:46 am
Ive never seen an aluminium back box either they're usually mild or stainless steel?
To sort the "pipe leans to centre of car" get a hacksaw and cut a pie section out of the exhaust like the diagram below. The diagram is when looking from the top of the exhaust. The point of the triangle should be facing the middle of the car. Do not cut completely through the exhaust, leaf a small amount of metal joining the pipe together.
The angle of the cut depends on how much you need to straighten the exhaust by. It depends on the amount you need to move the exhaust and the length of the pipe from the cut to the end of the tailpipe.
Once the exhaust has been bent you can then weld up the join and it will sit perfectly.
Matt
germ
Post
by germ » 21 Apr 2007 12:44 pm
i believe mine is stainless steel mmhh maybe the guy on ebay doesent know what he is talking about?
thanks for the thing on straitning ill have a go when i get my welder
will
Volvo 340
1988
Ali
Post
by Ali » 21 Apr 2007 12:51 pm
I fixed mine by going under the axle instead
had that on my standard system with a backbox and on my 3" system now. Its because the original pipework and backbox are designed to sit at an angle but the tailpipe bends out of the back of the backbox on a 300 silencer. On a 340 you can really cut out those nasty bends because the petrol tank doesnt get in the way like on a 360
I tried going under the tank on the 360 and it had about 2" ground clearance! Heres the system I used to have on my 340... 2" and cuts out the 90deg bends
germ
Post
by germ » 21 Apr 2007 01:13 pm
^^ very nice
but my fuel tank is in the way
i tryed to do a 2" system from front to back in a straite line but tank is in the way, so lacking creativity i made a 2" pipe in original place it was coming out straite at the end but somhow when i put the box on it had moved/settled in a differnt place...maybe i can adjust it...somehow
and ali i dont know if ive said already but i reallly really like your car
will
Volvo 340
1988
