Comparing 360 to 340!!
Posted: 07 Nov 2005 10:20 pm
by 340GLT
Hi a quick question for those in the know!! Does anyone know if there is a differance between 60 and 40 drive shafts? Are the 60 ones any thicker?
Also can anyone clarify whether or not GLT springs are different? (Leaf springs) as i believe they are but have no guarantees!!
Cheers Adam
Posted: 07 Nov 2005 10:23 pm
by SoLaMaNdA
The drive shaft of a 360 is encased in a torque tube, 340's run normal shafts.
Posted: 07 Nov 2005 10:24 pm
Driveshafts not propshafts
Posted: 07 Nov 2005 10:27 pm
by SoLaMaNdA
ah, half shafts should be the same but can't confirm.
Posted: 07 Nov 2005 10:29 pm
I'm running with 360 drive shafts becouse the gaiters on my orriginals were split. They do feel a bit heavier but the od is the same. The thing I like about the 360 drive shafts is the bolts that came with them, 10mm head bolts not hex keys.
Posted: 07 Nov 2005 11:01 pm
by V6 Man
Same part No according to VADIS.
Posted: 07 Nov 2005 11:54 pm
by 340GLT
Cheers Rupert thats sorted that one out!!
What bout rear leafs?
Cheers Adam
Posted: 08 Nov 2005 12:06 am
by 5lab
apparently glts (and gle-i) had lower, wider track, but i'm not personally convinced
Posted: 08 Nov 2005 12:08 am
by 340GLT
i dunno when parked next to alis car my car was loads higher?? So who knows??
Cheers Adam
Posted: 08 Nov 2005 12:32 am
by pettaw
rear leafs have different part numbers in VADIS, but no different specs in the green book.
Posted: 08 Nov 2005 12:35 am
by 340GLT
Cheers Adndy i know what i will be installing soon then!!
Cheers Adam
Posted: 08 Nov 2005 01:13 am
by daffodil
hi i have some spec
the length is different up to 1980 and 1980 onwards
up to 1980 is 1260mm from 1980 is 1250mm
also they are colour coded but i have no reference to what code is what
but all this aside i do think that glt are stronger and lower
Posted: 10 Nov 2005 10:30 pm
I take it this question was thinking ahead for a little engine swap.
The drive shafts should be ok for the power and the prop should be ok as long as you dont take off hard. I do have a plan on how to fix the problem with the prop.
