Two sensors probably broken, only 3000km driven
Currently installed lambda does this:
After start, lambda does warm up and suddenly goes above 1Volt and then faints to 0, when I switch off engine and wait around 15 minutes it works similar way again.
Previous lambda started to show constant rich mixture, after I fit this new one it did read mixture properly, but when I did one overtake this new lambda stopped working.
I don't know lot of these sensors but I know that is is practically impossible to connect wrong. I have even wired extra ground to exhaust, so that can't be problem either.
I have removed and installed again this lambda, I have tried cleaning it, but always it works similar way
Position of lambda sensor is very similar that B200F has, so I think that should not be a problem.
Any ideas coming, even crazy ideas?
Thank you from help
