Post
by foggyjames » 26 May 2006 01:29 am
Sorry Andy, I'm going to have to disagree there. If Dexter is wanting to swap from carb to injection, he'll need a higher pressure pump. Carb pumps are generally high volume, but very low pressure. Flat-out, my standard pump makes about 5psi, average. EFI pumps tend to push more like 50psi. Mechanical FI ones tend to be even higher, IIRC.
You can get regulators which step the pressure down, allowing an EFI pump to be used with carbs, but not the other way around.
The standard mechanical pump is on the side of the engine block. The easiest thing is probably to fit the complete fuel system from a 360 injection.
