MOT and re-circ
MOT and re-circ
evening,
does the rear wiper need to work for an MOT?
also
i can see how re-circ works by pulling the metal plate up to block the fresh air inlet, 'cept mine doesn't. there is a vacuum cause my old econ gauge worked however nothing makes the re-circ do anything. the engine did whine a bit when i turned it on but then it went away. anyone had this issue before?
also
I dont think the rear wiper has to work as it's not quite as essential as the front ones! I've definately had cars that didnt have working ones that still passed.
Would probably come up as an advisory if anything
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
Yeah, I think it is if it is fitted it needs to work. I could be wrong, but I didn't take the risk on one of my cars which had a cracked fog light lense being a 360 GLT. So I covered them over with plastic, no one knew they were there then! It might be something very simple for the rear wiper, as the wires going to the hatch on the opening near the hing at the top often fail.
With regards to the recirc, Chris C would probably be the man to ask as he's fitted it from scratch. All I know is one car we did have it on, it had been disabled. I would guess the main thing to go wrong is the vacuum operated piston/pump part on the side of the heater box to operate the flap.
Re-circ is dead simple, basically you have a vacuum feed (same as the econ) the switch, a one way valve, then the piston.
As you have an econ gauge, try idling, making sure everything is stable, and pressing the re circ button in, the needle should go down a small amount (half a single o'clocks worth) for a second. If it doesn't you arn't getting vaccum through for some reason, if it does (which it really shouldn't, as that would prolly mean a leak of some kind somewhere, and that would mean the econ gauge would go down for a time longer than a second), the piston is not moving for some reason, prolly the bearings on the flap being tight.
Try running the re circ on the econ tapping if that still works (should be the same diameter pipe), and if you have a spare econ, put that in place of the piston. I have a feeling it could be your one way valve, its a inch long grey cylinder with an arrow on it, try running the system without if you can join the two ends of pipe.
Let us know what happens, it won't be a difficult one!
It should let air through one way yeah, I've never tried blowing on one to test though. Have you tried the system without the valve? All it will do is not hold the flap up when you turn the engine off.
