Mono Tubes
Mono Tubes
Post by classicswede » 30 Oct 2006 12:52 am
Don't you just hate it when someone posts about something they have done to their car and not post any pictures? Sure you do! well that is exactly what I am doing now! :P
I've completed the conversion from normal twin tube front dampers to a lovely pair of billy mono tubes! :D
It's taken me nearly a year from when I got the dampers to do it - i now wish I had done it soomer.
I will be posting pics later and let you know how it is done.
A M R
Post by A M R » 30 Oct 2006 01:17 am
bilstein monotubes!?!?!?! NICE!!!! :twisted:
arrgh less than a month to go for my driving test!!!!
Post by SteveP » 30 Oct 2006 11:03 am
Oohhh.... billes... this thread is worthless without pics :lol:
Post by Chris_C » 30 Oct 2006 11:26 am
Hehe, get the pics invloved pronto dude ;)
sven360
Post by sven360 » 30 Oct 2006 06:10 pm
Who is this Bill Stein chap?
Apparently his suspenders are the bollox :? :lol:
Post by classicswede » 30 Oct 2006 07:35 pm
I'll be posting pics later this week.
Very busy at the mo with MOT on the way.
Post by foggyjames » 30 Oct 2006 09:25 pm
It's a shame you're a bloke Dai, as you seem mighty hug-worthy sometimes! :D Will these be for sale?
Post by jtbo » 01 Nov 2006 10:58 am
What is advantage of mono tube design?
Post by foggyjames » 01 Nov 2006 07:37 pm
As far as I'm aware, the standard 300 series design is a monotube with an insert, but this mono tube will probably be a 'standard' (52mm?) tube which takes any old Billy insert, and threaded on the outside for use with a standard coil-over arrangement.
Post by classicswede » 01 Nov 2006 08:03 pm
99% of std dampers are twin tube dampers. This means you have the outer casing iner caseing and as normal a piston rod.
A Mono tube only has the outer casing with a piston rod just the same. The other difference with this is the gas is in a seperate chamber so it can not mix with the oil.
In a McPhurson strut the piston rod is used to locate the road wheel. Doing this puts massive strain on the damper seals. With a mono tube set the damper is positioned upside down and the outer shell takes all the strain. Also with a mono tube you have a top bearing so the damper seal do not get rubbed by the wheels turning.
I'm sure I have a good article explaining all.
I do hope to be able to supply this converion to any one who wants it.
girlracer
Post by girlracer » 01 Nov 2006 10:23 pm
Well I can say that a cetain person has already seen some photos of the conversion!!!!
I will leave you to guess!
vicky
girlracer
Post by girlracer » 01 Nov 2006 10:31 pm
Oooooh I forgot to say now that I have the mono tubes on the front the ride seems to be a lot smoother than before! I'm not feeling the bumps so muchand hopefully the suspension should hopefully last a little longer this time!!
Anyways catch you guys later!!!
vicky
Post by 340GLT » 01 Nov 2006 11:19 pm
girlracer wrote:Well I can say that a cetain person has already seen some photos of the conversion!!!!
:lol:
Post by redline » 02 Nov 2006 08:40 am
foggyjames wrote:It's a shame you're a bloke Dai, as you seem mighty hug-worthy sometimes! cheers James
the target of your affection being a bloke dosen't normally stop you James !!!!!
girlracer
Post by girlracer » 03 Nov 2006 09:41 pm
lol
vicky
