Volvo 340 breather tank
Minishonk
Post by Minishonk » 18 Jul 2007 03:06 pm
hey lads an ladies im new here looked on here a few times :) got a slight problem my fuel pipes have split from the tank.. sorted the pipes now but just wondering which pipe goes to what??
the ones with the red arrows on are the ones im not sure on
thanks
chris
Tourinki
Post by Tourinki » 18 Jul 2007 07:57 pm
what is that tank? what is it for? In thirteen years what we have had 300 series and what i have came across. I have never seen tank like that attached to fuel pipes.
1999 Volvo S80 T6 Quiet long distance cruiser.
1990 Volvo 360 GLi Waiting inspiration.
1989 Toyota Land Cruiser For days when wellies aren't enough inside the car.
1987 Volvo 360 GLi Being restored.
1986 Volvo 740 Turbo Sold, but not forgotten.
Post by SteveP » 18 Jul 2007 08:10 pm
That's a good point, I've never seen a tank like that either?!
Minishonk
Post by Minishonk » 18 Jul 2007 08:33 pm
its like a catch tank the cars stripped out i think ive sorted it now but still when turning hard it pisses petrol all over the floor
Post by classicswede » 18 Jul 2007 10:58 pm
All the 300 I have seen have it. I ripped it out on Vicky's car to save a little weight :D
Post by petefarrell360 » 18 Jul 2007 11:09 pm
It's definitely not there on EFI 360's, as I've never seen that tank either! Learn something new everyday!
Post by Chris_C » 19 Jul 2007 12:22 am
Haha, both mine have it ;) I'm also quite sure Beast did too, when I was stripping her out...
Minishonk
Post by Minishonk » 19 Jul 2007 12:25 am
well mines causing hastle its pissing fuel out during tight cornering its just had brand new pipes so dunno whats up with it! :cry:
Post by Chris_C » 19 Jul 2007 12:34 am
There you go mate, thats for a 1.7, but I'm guessing they are all the same. Part 43 should float open one end
Post by pettaw » 19 Jul 2007 09:39 am
Its an expansion tank to stop the main fuel tank leaking fuel everywhere when you fill up with fuel on a hot day.
Only 340s have it, the 360s have a different fuel tank and therefore don't have one.
One of the pipes is missing parts. On the top connection by the filler pipe, there's three hoses in that picture. The third hose on the right should be going into a small one way valve and then into the hole in the boot floor there and through out underneath the car, as its the main vent for the fuel tank. I presume that's why fuel squirts out all over the boot if you corner hard with a full fuel tank.
Minishonk
Post by Minishonk » 19 Jul 2007 05:19 pm
the 1 way valve is there u just cant see it from that pic ill take another soon because we have altered it thanks for the help :)
germ
Post by germ » 19 Jul 2007 05:28 pm
mine has it, looked at the pipes when i was replacing the rest.
Volvo 340 Image 1988
morgan105
Post by morgan105 » 21 Jul 2007 01:47 pm
The smaller loose top hose should have a valve connected to it and another hose from the other side of the valve down through the hole in the base grommet of the filler tube which will connect to a pipe to the tank, as pettaw mentioned.
I have a jpeg picture of the b14 and b172 connections here but can't figure out how to post images yet but if you send me a email address I can send it over for you.
morgan105 8)
Post by pettaw » 21 Jul 2007 05:49 pm
most people will have an 'email' button at the bottom of their post.
To post up images, you have to host them somewhere else. Most people either use their own webspace or a specialist picture site like Imageshack. You can then link to it using the 'IMG' button on the posting screen.
morgan105
Post by morgan105 » 21 Jul 2007 07:52 pm
Picture of expansion tank for b14 and b172 volvo 340. Click to view full size.
Hope this helps!
"Thanks to pettaw for pointing me in the right direction for getting pictures posted, just a bit more practice and they may be in the post rather then a link."
morgan105 8)
[Sorted, press the 'link to this image' button and copy Forum format #1. Andy]
