instrument panel...
instrument panel...
hello i gota a instrument panel off the 1.4 i got my new clutch shaft off and this got a revs gauge but on my volvo i have the clock
anyone no what else i need or how to wire the revs gauge up????
Drive It Like You Stole It
1989-Volvo 340 1.4
1989-Volvo 340 1.4
Normally take's a read off of the coil if I remember correctly
negative side of coil.
Ya'll need a feed off ignition,chassis earth and dash light feed.
If that's wrong sure someone will correct me
Write it in your heart.
The code of the West.
The grey renix wire is a dedicated tacho feed, it's not just the -ve side of the coil. Depending what year your car is mate, that wire might already be in the multiplugs that the dash cluster plugs into.
It should already be wired in on that age. Was the tacho working on the car the cluster came from?
