is it possible to remove the sump without taking the engine out? I have a beam at work i can use to suport it but dnt no weather the sump will pysicly come off around the subframe ect. Its a f7p if that makes any difference.
Thanks
sump removale
sump removale
'87 Volvo 340 'valver
Re: sump removale
Will come out, you will need beam to support on front engine mount only, gives you room to get to rear bolts then.
Its a pig of a job though is possible.
