magnumpi wrote:Chris_C wrote:Temp gauge runs at a quarter on the F7's, I have a feeling it's a gauge/sender mismatch as from memory we are using the renault sender but need to talk it through with Adam.
What was the case with that in the end? I ask as my temp gauge sits between only just passed the bottom mark, to quater with normal driving and takes ages to warm up and the heaters suck compared to how they were with the stock motor. Sitting stationary for a long time makes it go to around 3/4 then the fan kicks in, sound about normal or do i have issues?
It's almost ok, but your fan should kick in at a half not at 3/4. The engine is over cooling rather than it being a sender mismatch, thing is with stock plumbing it always will. I'm trying to sort out a solution but it's bottom of the pile atm, during the cold though mine sits on the C mark most of the time, even though oil temp is up.
zombeh wrote:Is it just cracked or does it have holes in it? Presumably it's a clutch failure of some sort that has been contained by the bell housing.
Cracked. Just about to go outside and pull it apart so will grab some pictars. I dont think it is clutch failure atm, I reckon it's misalignment (which means that Ben may have a technical thingy right....
V6 Man wrote:Thinking about it there must be something up with the drivetrain if you've managed to break a prop and shatter a bellhousing. we know that the 340 prop is capable of taking higher power than stock as Huskyracer had no problems with his at up to 180bhp and there are several F7R/P/whatevers running about with no issues (yet).
I do remember that the infamous Nessie (originally 5labs, then Foggys) had a bent output shaft from the bellhousing - maybe that's the weak point casuing the prop to twist and undue forces on the bellhousing. Either that or has a gearbox mount failed causing twisting issues?
I reckon Filthy has had this problem before, but not spoken to him yet. I'm pretty certain I remember him needing a super quick bellhousing once. I agree though, I think a gearbox mount could have caused this looking at the fracture, added to some other symptoms I've had recently. The crack is clean all the way round the output shaft housing behind the engine mounts, just as though a sideload had been put on the prop....
volvosneverdie wrote:Forgive me for trying to be technical, but didnt I read someone say knackered engine/gearbox mounts was possibly causing all the prop problems? Mis - alignment or some such mallady?
Where yours pucka chris?
I reckon so dude, no, mine are tired. I've been looking into a supplier to grab some new ones but struggling. Will know more hopefully later, but it's most likely to be this. The last couple of weeks (since the prop went) my gearstick moves under acceleration which is a sure sign of gearbox mount brokenness
I just hope it hasn't scrapped the crank whilst it was spinning, I reckon I'm already looking at least at a clutch, bellhousing, another prop and new mounts all round
