I've removed all the resistors from the old cluster!!
Nolan's 340 pick up D-project F7p (need help for Vss)
Re: Nolan's 340 pick up D-project F7p (need help for Vss)
I've taken the + from the horn and the same for the ground. In the middle (A), i've connected the wire from the module and another wire from Eprom (A6 primary speed sensor wire)
These three you need! (found a old picture
The - (negative is really close, the white wire in the picture) Don't mind the other wires..
You have taken the resistors from an old speedo? Or just picked up from your actually speedo?
I don t think having a green resistor from the old dash?
thx
thx
They should be on the 440/480 dashNolan wrote:You have taken the resistors from an old speedo? Or just picked up from your actually speedo?
thx
You mean i have to cut around the old dash resistors and connect it to the + ?
I've found a pic from my dash:
It's from a 440
Do you think i can put a 5v module reducer like this:
http://www.ebay.fr/itm/DC-DC-KIM-055L-9 ... 418c3dd9e9
It should be easier, i find 12v with the 3 resistors, maybe one is on the wrong side now...
It's from a 440
You need the three next to each other on the left. Cut them out and wire them in parallel, take notice of the direction they are installed. You need to do the same direction. Tape them together and put them in the + wire.Nolan wrote:You mean i have to cut around the old dash resistors and connect it to the + ?
It's from a 440
Yes, but the problem is that i don't know exactly how the resistors were placed, i don't have the same resistors than yours and can't see exactly with the only picture i have
http://www.hostingpics.net/viewer.php?i ... esized.jpg
Yeah, i'm going to try it tomorrow, just have to connect the 3 together like on the picture with a wire on each side, the up on +12v, and down on Vss + if i'm right...
Thanks!
Thanks!
ca avance bien
