Swedbricks' 360 Rallycross project - 'Gebakje'
Posted: 17 Aug 2022 08:53 am
Given that my 745 project is close to the point I set out to achieve barring an upcoming turbo upgrade and according tuning, the itch for a new project has been there for a while. I'm also planning to move to a place where I finally have my own garage, such that I'd have the space to get into more welding and paint. This thread will be a duplicate of my turbobricks thread, given I'm most active there!
Initially I started looking for a daf 66 or a classic mini, but being tall and having way too many b230 parts already I ended up buying a b200k from a volvo 360 instead:
It came equipped with everything needed to swap it, including mounts, a different oil pan, a special water pump setup and and the potentially different flywheel?
These other bits came along with it as well, a full exhaust and plenty of spare parts
My inspiration will be these rad 343 rallycross cars, which were clearly awesome:-P
I'd hoped to be able to just swap the bellhousing onto a 340 given the price/rarity difference, given the cool transaxle design used. But resident dutch 360 expert MrBorrie explained that this wouldn't work unfortunately, so I'm on the lookout for a 360.
Engine wise, the b200k didn't come with any reference as to where it came from making it hard to get approved, I don't mind since it has the center crank support anyway, and will be moving to a 90+ b230 block instead. I still have ITB's leftover, which in combination with some headwork, megasquirt/speeduino and a big cam should allow for some fun.
The chassis will get an assorted list of bits from ClassicSwede, to get it rally-spec for some forrest fun. A cage will also be added, as it is still build like a DAF, and is know for being crispy after some coastal seasoning. First thing first however will be to strip the b200k and pass it on
