Front disc upgrade
Front disc upgrade
Post by Speedy88 » 26 Oct 2010 05:56 pm
Bah, I'm afraid I'm blind. I know that it's common knowledge that there is an easy front disc upgrade for a 340 but I can't for the life of me find it. It was even discussed recently!
Any ideas peeps? Also would I need to change the callipers? Do these need modifying as well to fit?
Ta
magnumpi
Re: Front disc upgrade
Post by magnumpi » 26 Oct 2010 06:45 pm
I can't remember either, but thats because i took the easy option of just upgrading the discs, BlackDiamond do them off the shelf but not cheap being around £80.
Post by volvosneverdie » 26 Oct 2010 07:58 pm
magnumpi wrote:I can't remember either, but thats because i took the easy option of just upgrading the discs, BlackDiamond do them off the shelf but not cheap being around £80.
tommysb?
tommysb
Post by tommysb » 27 Oct 2010 02:15 pm
Heya,
Not been around here for a while....
AFAIK there's no EASY upgrade for the front - I required a bit of head scratching to get vented disks on there.
It's 'simply' just a case of fitting the disks, choosing a caliper that will work with the disks, and making an adaptor which will allow the caliper to locate into the correct position with respect to the disk and onto the strut.
vØlvØfreak
Post by vØlvØfreak » 27 Oct 2010 10:23 pm
these fit right away, but are not vented, only drilled
Post by Speedy88 » 28 Oct 2010 02:23 pm
Are they any good? I'm happy with the current braking power, its just brake fade that scares me :lol:
Post by Ride_on » 28 Oct 2010 03:11 pm
The are some nice looking disks on ebay by mintbitz, grooved and dimpled. I Havn't tried them yet though. I've only experience of 360 standard kit and hammering that.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Brake fade can be an issue, make sure your brake fluid is the best you can get and no more than 2-3 years old. You also need good condition and quality disks and pads. If you are really hammering it you might try a brake fluid circulation/cooling add-on. It uses the bleed nipple as a return feed
You might also find upgrading the rears to 360 spec will help.
Post by Speedy88 » 28 Oct 2010 07:23 pm
Yeah rear 360 drums was always an option but too much of a hassle right now. If I was gonna do it, may as well stick discs on. I hate those rear hubs. Before I think about doing that though the front brakes need to be stronger. The cooling idea sounds cool, also epic fail on the fluid front, it's full of hellfrauds best at the moment :( Looks like I'll have to wait a while then, need to get to A52 in Bristol to get this kinda thing done...
As for those ebay discs, nice one! I'll give those a go once the suspension project is over
Post by Ride_on » 29 Oct 2010 03:49 am
The rear drums are fine when in good condition, its just so many cars are neglected or sit unused for long periods, rear brakes hate that. The 360 rears are also a bit more robust than the 340 ones.
magnumpi
Post by magnumpi » 30 Oct 2010 11:48 am
As said BlackDiamond do grooved like mine, or you can go drilled, grooved and vented but they are over £100 but it's an easy off the shelf part.
If anything with my grovved ones you don't get fade as they get hot, they just bite harder :D
samueljon
Post by samueljon » 01 Nov 2010 05:51 pm
360 rear drums are better then??
and those discs on ebay are they straight fit on 340 calipers?
also is there a brake pad upgrade??
Post by Hell Driver » 01 Nov 2010 06:42 pm
magnumpi wrote:As said BlackDiamond do grooved like mine, or you can go drilled, grooved and vented but they are over £100 but it's an easy off the shelf part.
So you can get ones that are all three? drilled, grooved and vented off the shelf to fit the front without altering calipers?
343 DL (W 80) :-)
R.I.P. 77 343 DL vario :-(
vØlvØfreak
Post by vØlvØfreak » 01 Nov 2010 06:56 pm
I think not?
A vented disk is much 'thicker', how should this match with the original capilers?
I have the drilled ones of the pic I posted, I haven't tested them yet (are still in the box ;) ) But other people were enthousiastic about those combined with ferodo DS2500 pads.
Post by Hell Driver » 01 Nov 2010 07:27 pm
I thought it might not be that simple!
343 DL (W 80) :-)
magnumpi
Post by magnumpi » 01 Nov 2010 07:47 pm
My bad then, they were however very helpful when i rang them so might be worth giving a go.
They do Predator pads aswell which i fitted and i'm pretty impresed with them.
http://blackdiamondperformance.com/index.htm
From the box pic it appears you can get all 3, or is it a case that if you have drilled, vented and grooved they just don't fit a standard Volvo caliper?
