Unstable at speed
Jak
Unstable at speed
Post by Jak » 25 Mar 2013 10:58 pm
Right my 360 loon, starts driving all over the place at like anything above 50 quite vilently, though it was axle tramp checked the bolts and they are all tight just searching for some ideas before I burn the car
jon-ovlov
Re: Unstable at speed
Post by jon-ovlov » 25 Mar 2013 11:12 pm
How are the bushes on both the anit tramp bar and leaf springs? Spring seat bolts all ok?
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Evoman
Post by Evoman » 25 Mar 2013 11:16 pm
Check all bolts at the back, wheel bearing collapsed? wheels balenced? axle bent? did you do any damage when you smashed that wheel?
Rubenv340
Post by Rubenv340 » 25 Mar 2013 11:24 pm
Sorry for hijacking.
What is the feeling if you have a bad wheel bearing? Front or rear.
Thanks.
Jak
Post by Jak » 25 Mar 2013 11:28 pm
The smashed wheels was the front, replaced all the lowering block bolts with new ones, anti bar bushes seem fine so do the leaf spring bushes. Going to rip the front apart and see what I can find tomoro
Post by classicswede » 25 Mar 2013 11:31 pm
From experiance I would always look at the front end first. Most rear end issue hardly show up other then when near the limit.
Check for even the faintest amount of play in the front suspension. Rember you will need to have the wheels off teh ground to check or the weight of the car will hold things in place.
Jak
Post by Jak » 25 Mar 2013 11:43 pm
That's the plan for tomoro DAi
Post by Speedy88 » 26 Mar 2013 08:53 am
My money would be on radius arm bushes
Post by Ride_on » 28 Mar 2013 10:08 pm
Sounds like something bent on one side, wheels not aligned but also something else. Check the position and direction of all the wheels. Sounds bad enough to be visible.
Jak
Post by Jak » 30 Mar 2013 11:24 pm
Replaced all the bushes with Poly bushes. And rebuild a front shock that was leaking. Seems to be fixxed know
Post by classicswede » 31 Mar 2013 12:04 am
There we go :D
