So I'm really looking at advice on how to get her stiff without such an in depth suspension change. I'm currently running standard shocks and springs on lowering blocks, so straight away I was going to swap the shocks for some spax ones I've already bought; now is this a good idea or I would I be better off with Landy ones, I know they can over-damper but is that what I need, or are spax even stiffer at max?
I also heard you can double up leaf springs,and make them even stiffer if you run the second spring upside-down, anybody done this? Any noticeable difference? Also apparently then i can remove the lowering blocks, giving me more ground clearance
Also is there any anti-tramp bar that was made for the 340, or any that fit or can be adapted to fit?
thanks, Dave
