Help find a part
Help find a part
Hello ,
I need to find a new or used part on which the rear wheel is mounted. Don't know how it's called. It should look something like this
http://s214.photobucket.com/user/turbea ... 7.jpg.html
It's from a 360. Haven't removed it yet. Maybe someone knows the part's number? If I can't find a new one maybe I can find a used one ? What other volvos used the same part?
Re: Help find a part
Half-shaft?
Wheel Hub?
Wheel axle?
No. 9
360rearaxle by macplaxton, on Flickr
360 up to chassis number 120999 part number 3280432
340 / 360 from chassis number 121000 (MY1986) Part number: 3245853
No. 9
If you need wheel flange, hub or or the bearing, you will need a new bearing. Taking out the wheel flange will destroy the bearing.
Its a bit tricky but do-able.
viewtopic.php?f=54&t=10548
I still don't get how to take the wheel hub of. This is how it looks without the drum.
As you can see it needs new studs. Do I need to remove the axle somehow to get the hub off?
Disconnect the outer driveshaft CV joint first. Then undo big nut on inside.Kristupas wrote:I still don't get how to take the wheel hub of. This is how it looks without the drum.
See: viewtopic.php?f=36&t=7264 "Steering PDF" page 45 for more details.
Then you need a good puller. Also as above you will need a new bearing.
And what is that twin turbo 6 pot going into?
