drift suspension
nicksonmotorsportltd
drift suspension
Post by nicksonmotorsportltd » 16 Feb 2009 10:01 pm
building drift 340 at the min. im told it has uprated shocks but unsure of what they are until i remove them,
whats the done thing when setting up a 340 for drift.
will be running 16v engine.
-x-salmon-x-
Re: drift suspension
Post by -x-salmon-x- » 17 Feb 2009 12:45 am
i have mine lowered same as yours, then damper wise monroe gas shocks on the front and am gonna be running spax rear sdjustables its a good set up :)
Post by classicswede » 17 Feb 2009 07:40 pm
Is it my springs you have up front?
-x-salmon-x-
Post by -x-salmon-x- » 17 Feb 2009 11:50 pm
i do but i think nicks are similar but not necessarily your ones...
Post by nicksonmotorsportltd » 19 Feb 2009 06:42 pm
hey salmon, do u know exactly what is on my car as i dont have a clue. been told shocks and springs on the front. lowered at the back unsure of dampers etc.
Post by SteveP » 19 Feb 2009 06:46 pm
Have a look - you'll be able to tell what's on the rear just by having a crawl underneath. Obviously fronts will be harder to determine...
-x-salmon-x-
Post by -x-salmon-x- » 19 Feb 2009 08:38 pm
hmm dont know too well i know yours is lowered 2" rear on i think 3" on the front adn think its standard shocks on the rear possibly gas fronts not too sure i didnt spend too much time with it most time on the soarer when i was at his. but thats what i think it was or was told ask bennie? or we're meant to be coming down to you at some point to drop off some bits for you to do or something and pick up my exhaust so could always ask him then?
Post by nicksonmotorsportltd » 19 Feb 2009 11:23 pm
ok cool. yeah the car will be coming apart for the rebuild, cage etc and 16v running over 200hp. so will get a look then, just wanted to see if any1 knew already then i can budget for extra suspension bits if need be. want a decent setup really seing as could be running between 200-240hp depending on my budget.
any1 know of decent brake upgrades. cheers
-x-salmon-x-
Post by -x-salmon-x- » 20 Feb 2009 01:04 am
what you doing to yours to run that much bhp... i need some inspiration to bump mine up that much... seeing as i pretty much have the same engine.
Post by nicksonmotorsportltd » 20 Feb 2009 07:07 pm
clio williams f7r 2l engine. 12-1 high comp pistons and con rods, port and polish head, kent cams, webber 45dcoe carbs.
manifold-exhaust,
engine was already running around 180bhp with head,cams and hill power ecu stg2 . dcoes plus high comp bottom end should see well over 220.
just hope transmission is up to the job. any1 know if i could get a rwd gearbox that mounts to the f7r block. thinkin of changing the rear end to mk2 escort setup running atlas lsd axle plus 5 link. if possible.
Post by filthyjohn » 21 Feb 2009 10:24 am
Given the revvy nature of the F7R I should think the box will be fine at those power levels, as long as it's in good condition. The diff may struggle though, but just don't go spinning one wheel, with that power both should be spinning most of the time. Changing to a front gearbox is a lot more work than checking and rebuilding your existing box.
-x-salmon-x-
Post by -x-salmon-x- » 21 Feb 2009 03:54 pm
i found out what suspension your meant to have lowered as i said and apparantly kyb? gas shocks on the front and land rover shocks on the rear is what bennie said... hope it helps and is right? :S
