Post
by jtbo » 26 Nov 2006 03:49 pm
Gulbrandsen_Racing wrote:and 68.81 is a wrong number..?
Remember that it is reinforced caravan springs, what is done to it?
Sorry about late reply, I'm blind or something.
That 68,81 is just a guess based to pic and details I pick from text above, that is about twice as stiff as stock 360 front springs.
Citroen ZX Dturbo -97 -daily-
volvo360gle/340turbo
Post
by volvo360gle/340turbo » 28 Nov 2006 11:02 pm
wat model of escort they out of? i take it they are fronts? thanks!
Andrew
1988 360 gle
1990 340 gl (turbo conversion)
1991 340 LE 1.4 (29000 miles on the clock)
dalahare
Post
by dalahare » 06 Dec 2006 03:01 am
I've found a local manufacturer that will do custom springs for me for $120au, that's pretty cheap, but he wants the following information from me.
ride height (wheel arch to hub)
installed spring height
and then they want one of the springs to test it for stiffness, and will make the springs to suit whatever i want, stiffness and rideheight.
The height i basically want it where it is now, lots of rough roads around here and i do go off road a bit, so the bump travel and clearance will be appreciated, but stiffness i'm a little unsure about, I think about twice as stiff as the originals should be the go, but though i would get the opinion of someone who has fitted stiffer springs first...
I figure if i go to stiff i'm going to struggle to find dampers strong enough to cope?
