Post
by Speedy88 » 18 Feb 2011 06:36 pm
A neighbour gave me an old, opened bottle of castrol brake fluid. When I say old, we're talking maybe 5 years-ish. The fluid seems good and being the cheap b*stard that I am, who can refuse?
Question though - is it worth using? Little bird told me that old brake fluid looses it's functional abilities when sitting on shelves
Post
by volvodspec » 18 Feb 2011 06:44 pm
yep, throw it away!
brake fluid is hygroscopic, wich means it attracts moisture. this is good since when it's in your brake lines there aren't any seperate drops of water wich can boil up and turn to a gass wich gives a spongy feel on the pedal when you're doing a bit of braking.
the older the fluid gets, the more moisture there's in it and the lower the boilingpoint of the fluid.
normal in car life of the fluid is 2years, maximum lifespan of 3 years. opened tins have to be used as soon as possible
theo2468
Post
by theo2468 » 18 Feb 2011 06:56 pm
brake fluids hygroscopic meaning its absorbs water and causing you to have a spongey pedal, lets just get striaght to the point, CHUCK IT!
C25 ECV-1985-Mk2 340GL-
Kessy
A889 VUY-1983-Mk2 360GLS-
RUF
Best appreciated when open.
theo2468
Post
by theo2468 » 18 Feb 2011 06:58 pm
didnt see that post before mine
Kessy
RUF
Post
by Speedy88 » 18 Feb 2011 07:31 pm
Awww. Cheapness ftl
CBA
Post
by CBA » 18 Feb 2011 07:31 pm
when it gets warm it makes water vapour, may as well be air, causing spongy pedal, when it reaches 100oC it makes steam, locking the brakes suddenly when you're giving it the beans.
Post
by macplaxton » 18 Feb 2011 08:24 pm
Speedy88 wrote:Little bird told me that old brake fluid looses it's functional abilities when sitting on shelves
Well it doesn't loose as such on the shelf, just when moisture gets into over a long period of time and reduces the boiling point. Hence you should change your fluid every 18-24 months.
Speedy88 wrote:Question though - is it worth using?
Not in the braking system, but probably has some use somewhere else in the garage (paint stripping?), if you really are that cheap.
If disposing of it, dispose of it correctly, blah, blah, blah.
72 DAF 44 Estate 78 Volvo 343DL Black Beauty
82 Volvo 343DL CVT
88 Volvo 340DL Diesel
CBA
Post
by CBA » 18 Feb 2011 08:59 pm
it can be used to clean brakes very effectively and it doesn't damage the seals.
L14MNP
Post
by L14MNP » 20 Feb 2011 12:25 am
Pour it over one of your enemies (cars).
I wouldn't risk using it in the MC.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
Nimminz
Post
by Nimminz » 20 Feb 2011 01:03 am
I've been told recently that clean brake fluid that hasn't been in a car, wont damage car paintwork?? I have a bottle (opened) somewhere. there's 2 quid's worth still in it, i'm not chucking mine. Maybe in an emergency it would be better than having no brake fluid in the car.
L14MNP
Post
by L14MNP » 20 Feb 2011 01:29 am
I've poured it over a car before (cunt deserved it) and it did SFA. I am inclined to agree with you mate.
STREETO WITHDRAWL
Post
by volvosneverdie » 20 Feb 2011 10:41 am
L14MNP wrote:I've poured it over a car before (cunt deserved it) and it did SFA. I am inclined to agree with you mate.
Bricks are cheaper.
CBA
Post
by CBA » 20 Feb 2011 12:20 pm
oof.. valve cutting paste smeared on the wipers.....
