wheel stud dimensions
Anyone know what length and thread pitch the standard wheel studs are? Also is there a cheap upgrade to getting longer studs? i want to run a 30mm bolt on wheel spacer upfront and i dont think the standard studs are long enough.
Re: wheel stud dimensions
I *think* scooby ones fit. Pretty sure they're М12х1.25
Scooby studs require the Volvo hubs drilling out to 14mm iirc. I have some here, but like many things on this car, I haven't got to that stage yet.
No-one has reported a direct swap as of yet.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
I've got scooby studs on a set of legs i have in a box somewhere lol im not sure if they've been drilled out, i'll have a look tomorrow and get back to you
They're definatley longer than the standard ones
how much longer guys? enough to fit 25/30mm bolt on spacers too?
You might want to look at Ford Escort MK2 when they went metric.
Think you may be surprised.
Obviously,getting extended studs will then be pi$$ easy.
Write it in your heart.
The code of the West.
