Rear radius arm substitute
Posted: 05 Nov 2011 12:19 am
Well I'm still trying to sort a solid replacement for my rear radius arm / axle control arm.
No sign of any bushes to replace in the old arm, Dia did suggest he might get them done but its not his full time job, and it will be tricky, especially the press fit one at the chassis. Someone also suggested rose joints so I am going down that route at the moment and come up with some strange discrepancies.
The large end at the chassis has a 12mm hole in the bush core but the hole in the chassis is only 10mm, so it seems the original design has a 'loose' bolt relying on the clamping force to the chassis. Anyone confirm or deny this, is there a sleeve missing? What is the bolt length? (I've forgotten which bolt is the right one)
The other end is a 10mm hole.
Both are 32mm wide.
The M10 rose joints are only 14mm wide, and I got tapered washers to go with them, building it out to 24mm, leaving a 8mm gap or a 14mm one if you include the 3mm washers normally fitted at the axle end. So I could replace the 3mm with 7mm washers/spacers, or get 4mm additional ones (maybe better to standardise both ends as the chassis end doesn't have additional washers).
Alternatively I could go for M12 joints and add in M10 converters which will build them out more.
I plan to make a straight linkage and let the rose joints take up kink, get some 17mm heavy tubing and weld M10 bolts on. Both joints are right hand thread so it can only be adjusted by 0.75mm increments (turning one joint 180deg), I figure that is fine as the axle end is adjustable.
Is there likley to be a significant increase in road noise, since I am no longer bushed?
Both are 32mm wide.
