Just tried buying CV boots from ebay, not a good experience;
J&R BK40 - Rubber seems good quality but has a large metal back that holds it on with the bolts such that changes the design strength. Probably ok but too different for my restoration.
Motaquip VCV270 - Seems ok, but only 1 left
Bailcast DBC100 stretchy - Too big, 80mm large end to fit 52mm rim.
ECP next, Incidentally anyone know what this part on ECP is:
'SKF Top Strut Mounting Kit (Front Axle) Part No.: 669750010 '
If its a top spring plate, we can knock out another special part that is NLA from anyone.
CV boots on ebay + top spring plate?
Re: CV boots on ebay + top spring plate?
More likely to be the SKF bearing set VKD 35012 T under a ECP barcode.Ride_on wrote:'SKF Top Strut Mounting Kit (Front Axle) Part No.: 669750010 '
I might have a boot kit or two knocking around, I'll have look for them if you like.
I was coming to that conclusion too, since SKF mostly do bearings. Can't get ECP on the phone and their web chat is useless, past caring now.
ECP website is a steamin' pile o'cack. Ditto GSF.
Where do they get these programmers from?
