Front coil springs - Replacement
Posted: 08 Oct 2012 09:13 am
by kelvingenders
Does anyone know when these need to be replaced. My 360 GLT seems to be very noisy at the front. I have replaced all parts, bearings, track rods shocks etc, but there is still a big thud when I go over bumps. Could these be knackered, or is this just the model!!
Re: Front coil springs - Replacement
Posted: 08 Oct 2012 10:02 am
Chances are the springs have sagged. What shape are your dampers in? Worn out dampers will cause a rough ride.
What are teh roads like where you are?
Posted: 08 Oct 2012 10:43 am
by kelvingenders
Brand new dampers - gas ones from scandix
Posted: 08 Oct 2012 11:30 am
Do you have bump stops fitted? Is the thud from the spring full compressing?
Posted: 09 Oct 2012 12:43 pm
by kelvingenders
Bump stops fitted and new
Posted: 10 Oct 2012 12:16 am
ARB link rods? The later versions with ball joints attached under the spring plate do get worn after 100K or so and clunk over bumps.
I can't imagine it is the springs unless they are broken, even then it should just drop.
Posted: 11 Oct 2012 11:20 am
by kelvingenders
link rods are new...have ordered new springs
Posted: 14 Oct 2012 04:31 am
by kelvingenders
Have taken the ARB link rods off. The car is much, much, much quieter. I'm replacing the poly Control arm bushes with rubber ones. I think this is also where a load of noise is coming from. Problem solved with money ...again
