longer bolt on wheel hub?
emyrdal
Post by emyrdal » 15 Nov 2012 12:25 am
I'm not sure about this, but is it possible to change the bolts one the wheel hub it self to someone that's longer??
i have got some wired rims, which are really thick at the senter, and i'm afraid the nuts won't get enough to grip to. if you guys know what i mean by that..
i haven't measured the original bolts, but i'd like them to be a good 40mm longer. at least. and also at the back.
do any of you know if this is possible?? :?
86 360 (344) B200K Blue with 3" slam, daily driver. 8x13 Allycat 175/50
86 360 (344) B200K Blue parts car - Crushed
88 360 (344) B200F Black, Stock - SOLD
Re: longer bolt on wheel hub?
Post by classicswede » 15 Nov 2012 11:43 am
Search for "Subaru studs" on this forum for teh answers.
emyrdal
Post by emyrdal » 15 Nov 2012 02:19 pm
ah, thanks! didn't realize it was "studs" but now i found a whole lot! thanks Dai!
Post by Ride_on » 15 Nov 2012 04:41 pm
For the rear you will probably need new bearings if you want to change the studs, as the short axle removal damages them. Its doable but tricky.
emyrdal
Post by emyrdal » 15 Nov 2012 05:15 pm
Ride_on wrote:For the rear you will probably need new bearings if you want to change the studs, as the short axle removal damages them. Its doable but tricky.
Do you have any pictures to show me? i really don't know how to do this. i'm just learning by doing :mrgreen:
Nimminz
Post by Nimminz » 21 Dec 2012 01:04 pm
