longer bolt on wheel hub?
Posted: 15 Nov 2012 12:25 am
by emyrdal
I'm not sure about this, but is it possible to change the bolts one the wheel hub it self to someone that's longer??
i have got some wired rims, which are really thick at the senter, and i'm afraid the nuts won't get enough to grip to. if you guys know what i mean by that..
i haven't measured the original bolts, but i'd like them to be a good 40mm longer. at least. and also at the back.
do any of you know if this is possible?? :?
Re: longer bolt on wheel hub?
Posted: 15 Nov 2012 11:43 am
Search for "Subaru studs" on this forum for teh answers.
Posted: 15 Nov 2012 02:19 pm
by emyrdal
ah, thanks! didn't realize it was "studs" but now i found a whole lot! thanks Dai!
Posted: 15 Nov 2012 04:41 pm
For the rear you will probably need new bearings if you want to change the studs, as the short axle removal damages them. Its doable but tricky.
Posted: 15 Nov 2012 05:15 pm
by emyrdal
Ride_on wrote:For the rear you will probably need new bearings if you want to change the studs, as the short axle removal damages them. Its doable but tricky.
Do you have any pictures to show me? i really don't know how to do this. i'm just learning by doing :mrgreen:
Posted: 21 Dec 2012 01:04 pm
by Nimminz
