Page 1 of 3
Lowering anyone????
Posted: 08 Sep 2005 11:51 am
by 340GLT
Well these are the lowering blocks i made at college. I havent got round to fitting them yet as i am getting some front springs from Dai!!!
Anyways they are 40mm!!
What you reckon guys?
Cheers Adam
Posted: 08 Sep 2005 06:33 pm
by bodejodel
If they fit and you are happy with them I might be interested...
Posted: 08 Sep 2005 08:28 pm
by 340GLT
I suppose a small production run, maybe possible!!!
Cheers Adam
Posted: 08 Sep 2005 09:36 pm
by bodejodel
I guess the small hole is where the pin on the leaf goes in and the big holes are for weight saving?
Is it aluminum or steel? (looks like steel...)
Posted: 08 Sep 2005 10:37 pm
by 340GLT
Yeh that is correct mate. They are steel, but could be made in ally to make them super light!!! i made them from steel as i had it and it didnt cost me anything but they may get changed at some point!!!
Cheers Adam
Posted: 09 Sep 2005 01:41 am
by robbieg
u fancy making a 60mm set?
Posted: 09 Sep 2005 01:06 pm
by 340GLT
The only problem with doing a 60mm set is trying to lower the front the same amount!!! I'm gonna struggle getting the car to sit level doing a 40mm!!! But when i'm back at college i could prob make a set up!!
Cheers Adam
Posted: 09 Sep 2005 03:26 pm
by robbieg
could always stick a bag of sand under the bonnet?
Posted: 09 Sep 2005 03:31 pm
Erm where? Someone decided it was a good idea to put an engine under there
Posted: 09 Sep 2005 03:32 pm
by redline
sounds like its
HACKSAW TIME
yeehaw
Take the hacksaw in your hand
cut a coil (just one strand )
drop your car down off the jack
your car is lowered ,just like that
Posted: 09 Sep 2005 04:45 pm
by robbieg
seriously im thinking about it, take the spare wheel out, and stick a bag of cement in there, spare wheels are for pussys anyway
Posted: 09 Sep 2005 05:02 pm
by RandomHero
Walking or taking public transport home when you have a flat tire is for pussies
Posted: 09 Sep 2005 06:50 pm
by bodejodel
I believe the coil is still under tension when the car is jacked up...? could dost you a couple of fingers when you start cutting a tensioned coil...
Posted: 09 Sep 2005 07:44 pm
"Warning, this Redline Rap may cost fingers"
Posted: 09 Sep 2005 11:22 pm
robbieg wrote:u fancy making a 60mm set?
What is your current ride height
(see pic)
60mm at the front is possible from standard but most 300' have sagged almost that much!!
Oh Adam are going to fit locating pins in your blocks as they are needed to locate the srings.
