rear leaf springs
Posted: 19 Oct 2007 10:43 am
by mgarageu
hello to all
is there any difference between model years or/and installed engines/gearboxes - i mean in leaf actual sizes - thickness?
any info is welcome
thanks to all
1
Posted: 19 Oct 2007 11:52 am
by Fuse
Yeah there are differencies between 340 and 360 (ride hight mostly I think, maybe stiffness too) and 360GLT leafs differ from the "normal" 360. (~2cm lower) I also think that Australia got heavy duty leafs. I can check VADIS for part numbers later, I'm at the uni right now.
Posted: 19 Oct 2007 01:02 pm
Fuse is right about 360 ones being a little stiffer and lower. You do you to watch though as many cars have has the springs changed at some point.
Posted: 19 Oct 2007 07:25 pm
by petefarrell360
Yeah Dai is right, check the part number if you can, normally in the rear hanger area on the return curve of the spring near the rear valance, a bit of a standing on your head trick! GLT springs are the lowest and stiffest springs.
Re: rear leaf springs
Posted: 31 Mar 2010 10:40 am
by ty360volvo
well thats good to here i just got a 360 GLT:)
dose any thing chang thu out the years? mine is a 1984 from australia
