willowdog
Post
by willowdog » 20 Dec 2005 10:20 pm
Hi
I bought a 360GLS recently. Lovely condition, 106,000k's - just under 1/4 k's of my last 245GL
and Volvo number three out of four cars owned
- I am a little upset that there's no rear speakers.
There are no wreckers here that have any left so is there any chance of someone posting a pic of what the mounts look like. I have the cover plates but it looks like nowhere to install the actual speakers. Or am I being dumb and I should look under those coverplates?
William
Post
by Chris_C » 20 Dec 2005 10:26 pm
The covers should be in two equal sized parts, with tiny screws holding the outside grill to an inner plastic plate, the plates then both screw onto the car panel and have a 4" dia round speaker screwed to them. I'll see if I can find a pic, or my spare set of covers to take one!
Post
by foggyjames » 21 Dec 2005 02:33 am
Welcome!
I'm guessing you're referring to the marked out sections in the rear pillars? If so, you cut those out, and mount away! The cutouts in the metalwork behind are for a 4x6" speaker, but the originals use an adaptor and a 4" speaker. I'm sure a UK person could post you a set of mounts, as they're fairly common over here.
arnagath
Post
by arnagath » 21 Dec 2005 05:43 am
Pull speakerwires yourself and put some good speakers in back..
Its really simple!! I have 6x9 speakers in back of my 340,sounds great!!
Volvo 340 GL `87 B172K +
Volvo 360 GLT `87 B200E =
Volvo 340 GLT B200E *sold*
Volvo 245 `86 B200K
willowdog
Post
by willowdog » 21 Dec 2005 08:39 am
Sweet.
Thanks James.
I think i'll go that route rather than chopping the shelf up. It's the first one I've seen here or in Melbourne that is still in one piece!
Having said that, could get an plate made and put 6" Vifa's in there with some nice Vifa dome tweeters. mmmmmm
Those 6x9's do look a little better than 4"ers...
William
Post
by redline » 21 Dec 2005 10:19 am
Hi ,
if you do go the parcel shelf route , you could always do what I did
I glued and screwed three 6mm pieces of mdf together the top one is slightly wider than the lower two and slides in the channels where the parcel shelf used to fit , then I placed the original shelf over the top and glued it to the mdf (its also held by the speaker mounting bolts , the shelf still slides in and out (although i made it a much tighter fit to stop vibration and give more support ) It looks original but is much stronger and gives better acoustics
arnagath
Post
by arnagath » 22 Dec 2005 09:06 am
looks nice!!
Volvo 245 `86 B200K
Black_360_GLT
Post
by Black_360_GLT » 19 Jan 2006 12:16 am
My GLS and GLT have 4x6 speakers stock, no adaptors for 4inch speakers foggy.
Al
'87 360 GLT (5dr), 100k - SOLD
'89 360 GLT (5dr), 145k - SOLD
'88 360 GLT (5dr), (B200E),16''rims. smoked lights- FOR SALE
'83 360 GLS (5dr), 127k (B19) - FOR SALE
Post
by 340GLT » 19 Jan 2006 01:02 am
Honestly Al thats odd, i took a pair from a GLT near me to put in the blueline and they were only 4" ones.
Cheers Adam
petefarrell360
Post
by petefarrell360 » 19 Jan 2006 01:09 am
The one's I've seen have all been 4", but it would make sense if they were 4" x 6" as Volvo made the cutouts that way! Maybe earlier or later speakers are different? There is also the possibility that some are the saloon shelf speakers, which would probably also be 4 x 6, so would fit the openings in the hatch.
Post
by SteveP » 19 Jan 2006 10:06 am
Black_360_GLT wrote:My GLS and GLT have 4x6 speakers stock, no adaptors for 4inch speakers foggy.l
The thing is Al, they aint stock!
(Atleast on the GLT anyway)
Post
by foggyjames » 20 Jan 2006 05:36 am
AFAIK stock rear mounts for a saloon are 4". Maybe this is a case of 4x6 hole but 4" speaker again?
I've only ever seen 4" in the rear 4x6 hole, but as Pete says, this seems wierd. Are yours genuine Volvo speakers Al? That might well help settle the debate! That reminds me, I should wire up Nessy's rears...yup...more channels of audio in the 340 than my 360...
Black_360_GLT
Post
by Black_360_GLT » 20 Jan 2006 09:30 am
The ones in the GLS are after market, but the ones in my GLT look similar to the 4inch door speakers, they have grills too.
Post
by SteveP » 20 Jan 2006 09:36 am
From the quick glance I saw in your GLT the standard mounts behind the grilles had been removed in order to fit the 4x6's
