Volvo VC608 radio code
anyone know any codes or how to calculate the code. just taken from a scrap yard and searched the car but no code.
1986 1.4DL - 147,000 - C746 VRT
I had one of those recently before I replaced it for a MP3/CD/CDRW player...
My code was: 7439 - maybe worth a try.
If you want the manual, I can maybe get some photos of it for you sorted out...
It had a section on how to disable the code (though you need the code to do this!)
But... the code disabling thing didnt work!
(IE have to enter code every time you turn the radi on) which is a little annoying... and this was meant to disable this feautre.
Good Luck, maybe that code will work!
Simon
Simon
two questions. any idea of the colour codes(?) for the LED that light up the radio front as i've los the pre set side ones and the replacments came from my old 'mono' c3001 radio. it looks a bit strange with two shades of green one brighter than t'other.
also is there a more specialised procedure for extracting tapes? every so often it won't give a tape back at all. and needs a day or so to calm down before the eject will work.....
chris_rg24
OK first of all the moving doodahs mean that someone has entered the code incorrectly and the radio has locked out. You need to switch the radio on and wait for the doodahs to stop moving. depending on how many times its been entered the radio locks out for 1 minute, 2 minutes, 4 minutes etc etc it keeps doubling so you might be a while.
Once you just get a -C- symbol you then press 1 and you should get a - on the left of the display. Use the arrows to select your first digit. Once you've got it, press 1 again to move to the next digit. Repeat until the code's entered.
Hope that helps.
Hope that helps.
chris_rg24
