'How to...' - Sunroof
Doeke Dobma
Post by Doeke Dobma » 16 Jul 2008 08:15 pm
Hello fellow-300 drivers. In the coming weeks my '86 360 GLE will be 'renovated'. I don't know if that's the right word, is literally translated from dutch, but you'll understand what I mean.
This week I am removing all possible parts form my car, so the renovation and paint job will be cheaper(I'm a poor poor student...;)). I'm pretty much done with everything, but I really have no idea how to remove the sunroof. I only need the top plate, the metal thing with the rubber around it. I need to put on a new rubber and in needs to be removed so they can renovate it easily. Does anybody know how to do that? I would be very thankfull...
Post by petefarrell360 » 20 Jul 2008 12:57 am
As it's late, I'll post up a how to guide on the sunroof removal when I get five minutes! To give you a start, the interior trim panel unclips at the front on poppers like clips that push into the roof, I've got a panel removed that I can take some pictures of to show the locations of them. The rear unclips, which means you need to be able to tilt the roof open at the back to undo those. That is on a bendy piece of metal each side which needs to be slid towards the front of the car from memory to release it. Be very careful of the white plastic blocks that fit in the runners, they will probably be brittle and may break easily if any force is applied. Remind me if I forget to post more info up!
alf
Re: 'How to...' - Sunroof
Post by alf » 09 Apr 2009 02:59 pm
Hy Pete! Can you upload those pics, i also need to fix the sunroof (something is broken), it is not moving at all? Thanks!
ps-i noticed that the last post is from 2008 :) .
the early bird gets the worm
Edcase 300
Post by Edcase 300 » 09 Apr 2009 07:46 pm
id love to know also... :wink:
mine is buggered atm
cheers matey sm4
One Day... Volvo 360 Turbo ;-)
Post by Chris_C » 10 Apr 2009 12:37 am
To see whats going on, tilt the sunroof up (yes, I know this is pretty much impossible when it's broken, but there isn't another way I'm aware off!!) then at the back there are two peices of spring steel running across the car, about 3" long. Pop these out of the roof panel by twisting them, and the lining will drop out the back. Then, you need to slide the roof back (again, when the roofs screwed... this isn't easy) and pull (sharp motion downwards) to release the trim clips from the front.
Now you can push the inner trim back out of the way, and panel is held on by the 8mm bolts at the front on the multiadjusters, and by 4 philips screws in sidewards.
I fixed mine the other day when I got my GLT, really should have taken pictures!
Edcase 300
Post by Edcase 300 » 10 Apr 2009 12:47 am
cheers boss thats beautiful sm4
alf
Post by alf » 10 Apr 2009 11:36 am
Thanks, it seems that this weekend is not going to be boring. sm4 i only hope it will not rain :lol:
Post by filthyjohn » 10 Apr 2009 11:41 am
I should fix the sunroof on my GLT, I started it yesterday after it's been laid up for a year. K-jet FTW.
Post by SteveP » 10 Apr 2009 01:02 pm
LE-Jet?
Post by filthyjohn » 10 Apr 2009 01:04 pm
I thought it was K jet. Something old-fashioned anyway, unglamorous but reliable.
volvo_850_GLT
Post by volvo_850_GLT » 28 Jun 2009 05:37 pm
Hey guys i starter a process of restauration of a 360 glt but i cant really understand how can i remove it... Please help me. Maybe is because of my English but i cant understand... its the only thing that is undone and it has rust...
Tks
volvo_850_GLT
Post by volvo_850_GLT » 29 Jun 2009 11:33 am
Great news, the sunroof is off, i read better the first post and i did it. Tks
Hugo
