dubstar
Post
by dubstar » 21 Feb 2009 05:31 pm
This is mildly annoying... ...and yes today I am practising the art of understatement
As soon as I turn the ignition on, the wipers pick up on standard speed, no matter what position the stalk is in. I can make them faster by clicking to that speed, but not any slower or off.
For now I have cut into the Blue wire for standard speed and put a switch in to turn them off. although if you move the stalk to off or intermittent then they're off again at the standard speed. (So they're currently usable, but not great)
They weren't like this when I parked it up. It's just developed over the weeks that it has sat while I've been away.
Any Ideas?
C70 2.4 GS Coupé
340 GL Special Edition
V70 2.5 20V SE - RIP
Post
by volvosneverdie » 21 Feb 2009 05:35 pm
Dude, youre not having much luck.
You havnt run over a black cat and then drove under a ladder and through 30 mirrors recently have you?
kaos
Post
by kaos » 21 Feb 2009 10:05 pm
you sure youve put it in the correct of slot and let it settle at its rate normaly if its halfway through a cycle it wil finish it before it stops
dubstar
Post
by dubstar » 22 Feb 2009 03:37 am
Yes, I have given it 'the benefit of the doubt' a couple of times it just keep on going.
A bit like that bloody energiser bunny.
As I say, I can't even get intermittent, if you select intermittent it just keeps wiping normally. The only change is if you select fast wipe.
So I now have a toggle switch... (It may become apparent, that I'm quite a fan of metal toggle switches
C70 2.4 GS Coupé
sven360
Post
by sven360 » 24 Feb 2009 10:16 pm
dubstar wrote:This is mildly annoying... ...and yes today I am practising the art of understatement
Any Ideas?
Probably teaching me Granny to suck eggs-but the stalk will activate a switch somewhere along the line which must be US.
Locate and replace would be my advice.
Write it in your heart.
The code of the West.
pistonpen paultje
Post
by pistonpen paultje » 05 Mar 2009 05:11 pm
Probably a worn wipermotor. Had that too once with the GLS. A Cam should operate a switch. But when its worn, it doesn't touch it.
