The bottom two on the left:
The problem is both of my examples have had the wires at the back cut at some point, and now I'm not really sure which wire goes where. The beer doesn't help either:
Ugh:
I want to wire up one of these block type connectors:
which should provide everything except the rear speakers.
AFAIK the wiring is as follows (I'm trying to describe a 3x3 block connector here):
123
456
789
1. 12V memory + ################### 2. 12V live (fused) ################# 3. electric aerial
4. left front loudspeaker - (stripe) ##### 5. right front loudspeaker - (stripe) ## 6. ???
7. left front loudspeaker + ############ 8. right front loudspeaker +######### 9. earth -
Then there's a second 2x2 block connector for the rear speakers.
12
34
left rear loudspeaker + ######### right rear loudspeaker +
left rear loudspeaker - (stripe) ## right rear loudspeaker - (stripe)
On all the radios, the wiring colours are different.
On the MTS stereo, the wires sprouting out of the back are
Black
Green (+12V fused)
Blue
Black w. yellow stripe
White w. yellow stripe
Black w. white stripe
Blue w. white stripe
Red
and two colours which look like they may go to the rear speakers
Black
Orange
Any ideas?
