Valve clearance on B200E
volvo300
Post by volvo300 » 07 Jul 2005 09:57 am
Hi.
I have installed a new cam (k-cam), and the valve clearance is as below:
# 1 exhaust: 0.35mm
# 1 inlet: 0.35mm
# 2 exhaust: 0.35mm
# 2 inlet: 0.35mm
# 3 exhaust: 0.30mm
# 3 inlet: 0.30mm
# 4 exhaust: 0.35mm
# 4 inlet: 0.30mm
My question is:
"Does it have anything to say that #3inlet,#3exhaust and #4inlet has 0.05mm smaller clearance than the others?"
regards.
Peter
huskyracer
Post by huskyracer » 07 Jul 2005 07:55 pm
b200 sould have 0.30 to 0.40mm valve clearance on the inlet and exhaust valves. Your clearances are spot on, the diffarence you have on 3 and 4 are due to slightly uneven wear, or manufacturing tollerances, but they are nothing to worry about, at work I regularly see heads with .5 mm diffarence between valves!!!
volvo300
To huskyracer
Post by volvo300 » 07 Jul 2005 10:11 pm
Hi.
Thanks for the quick reply.
I will start with this clearance and maybe later adjust them.
I´m about to overhaul a B230 and the head including the k-cam must go on that engine.
You can se all of it on: http://www.volvo300.dk
regards.
Peter
Denmark
antiekeradio
Post by antiekeradio » 07 Jul 2005 10:49 pm
would be _totally_ useless to do anything about these clearances. its just perfect..
bodejodel
Post by bodejodel » 07 Jul 2005 11:04 pm
I like the Estonian GLT saloon on your site... :P
Jeroen
volvo300
Post by volvo300 » 08 Jul 2005 08:09 am
Yeah. :-)
I found it while I was surfing around a couple of years back.
By the way. When I get the time, I will make a english version of my webpage.
regards.
Peter
Denmark
5lab
Post by 5lab » 08 Jul 2005 08:48 am
yeah it looks good
the only thing that bugs me about saloons.. why didnt they make a new back bumper? the rear bumper on the saloon is straight off the hatch, and looks pants!
Swapsea-'89 360GLT-swapped!
5lab
Post by 5lab » 08 Jul 2005 08:50 am
ooh just noticed
that is a 'smiths' temperature gauge from a pre-85 car. was it hard to fit?
bodejodel
Post by bodejodel » 08 Jul 2005 08:57 am
Indeed.. that's not VDO gauge...
Those hatch rear bumpers do look a bit silly on a saloon...
Jeroen
kalyyyyyy
Re: Valve clearance on B200E
Post by kalyyyyyy » 30 Sep 2009 02:51 pm
I have 0.4 on every cylinder, except 2 of them on wich i have 0.35.Do You think if that i would adjust the clearence to 0.35 to all the cilinders there would be a diference?
EvilRacer329
Post by EvilRacer329 » 23 Oct 2009 06:33 pm
Hi,
I've got a stock B200e in my 360 GTL and I was hoping to start the conservative tuning process with a livelier cam - 115bhp (at new!) from a 2 litre is just silly. I understand that the cam you've installed (K-profile) is one of the ones to have - how would one find out what cam was currently in place? And where on earth did you source the new one? Can't seem to find them anywhere...
Also, I'm assuming the more aggressive cams have more lift-on overlap, but I've read that the exhaust pulses these send back through the intake can cause trouble with the flap-style air-flow sensors...
Eventually i'll go berserk and change both intake and exhaust for throttle bodies and something properly tuned, but doing so on stock cams seems silly...
Thoughts?
Nick
'89 Volvo 360 GLT B200E & '97 Honda VFR 750
