last bunch of conversion q's
samueljon
Re: last bunch of conversion q's
Post by samueljon » 09 Mar 2011 11:53 am
so its just a push bike cable, brake/gear as long as it has the metal blob on one end?
Post by filthyjohn » 09 Mar 2011 11:53 am
No, gear cable is thinner and brake cable is all but obsolete now everyone has hydraulic discs. Whatever you use for the throttle you'll probably need to adapt it to fit the accelerator. I'd adapt a standard throttle cable, but can't remember what sort of fitting is on the manifold end. There are loads of universal throttle cables on ebay though.
Post by volvosneverdie » 09 Mar 2011 12:01 pm
samueljon
Post by samueljon » 09 Mar 2011 12:20 pm
cheers guys
JakeyG
Post by JakeyG » 20 Jun 2011 09:17 am
Gear/brake cable is about 3 quid from a shop, or 2 quid if you only want the inner!
And Each will have a different bit on the end so check which you want first - brake cables have a big bit and gear cables have a tiny bit :)
Edit: Holy bump :shock: Sorry
