running a b230ft in a 360
wiganer31
Post by wiganer31 » 04 Jul 2011 03:48 pm
as some will know im going to be doing the 2.3t conversion on my 360 soon, i know theres a few threads about this atm but my question isnt about the conversion and ive done a search but cant find the answer im looking for, im wondering what kind of brake and suspension setup people are useing? after market? or stuff of other volvos? if so what parts and what exact model? cant imagen the standard 360 stuff will be up to the job?
also while im here im looking for a solid flywheel not 100% sure of the one i need? but if you know and you have one i can use, let me know
wiganer31
Re: running a b230ft in a 360
Post by wiganer31 » 04 Jul 2011 09:03 pm
ahh bugger just realised that ive put this in the engine section sorry
wiganer31
Post by wiganer31 » 07 Jul 2011 04:30 pm
anyone got any info on the suspension side?
wiganer31
Post by wiganer31 » 07 Jul 2011 04:31 pm
Post by Ride_on » 14 Jul 2011 10:59 pm
Ths standard answer on brakes is the OE ones are fine in good condition with new fluid, you can high end grooved disks and race pads if you want.
The suspension is also generally 'OK' with uprated front springs and anti-roll bars. Some use assisters on the back (or 2 springs) and a rear anti-roll bar would be nice. Plenty of shocks available.
I'm just sticking with GLT height and uprated springs on the front of my B230FT saloon, monroe Gasmatic front shocks and KYB mono tubes on the rear, but not planning any race cornering. The GLTs where rather good factory fresh, ironing out the ropy worn out bits that have crept in over the years is the difficult bit.
Top spring plate and top bush are a bit of a weakness and have no well known AM solutions. Also rear radius arm adjustment is important for rear alignment, loose bushes aren't much good and don't have any available replacements except hand made standard rose jointed arms or something.
Classicswede does a few bits, polybushes springs shock etc.
wiganer31
Post by wiganer31 » 16 Jul 2011 07:20 pm
what uprated springs would you recomend? were stocks them for 300's? cheers for your info mate, just had a look at classicswede the -25mm front lowering springs for £60 sound good to me but what are they like for handeling? and whats postage like to the uk?
Post by classicswede » 17 Jul 2011 10:50 pm
Springs offer a big improvement in handling but best results are had with uprated dampers.
With the 360 turbo you will want extra stiff springs to take the extra weight.
Email with details of what the car is used for etc.
Regards
wiganer31
Post by wiganer31 » 19 Jul 2011 06:51 pm
just emailed you mate, i dont know why but i had it in my head that you was based outside of the uk lol
Post by Ride_on » 19 Jul 2011 09:41 pm
wiganer31 wrote:just emailed you mate, i dont know why but i had it in my head that you was based outside of the uk lol
English people!
Post by foggyjames » 02 Aug 2011 01:08 am
Well he is sort of outside the civilised world sm56 sm56 sm56
Just a thought - given that your car had an M90, you'll need a solid flywheel from an early 940 (or very late 240 or 740) with the M46 (4spd+OD) or M47 (5 spd) box. I've also just discovered (the hard way) that not all 940 turbo pressure plates will fit in a 360 bellhousing...at least not without 'adjustment' to the inside of the bellhousing. The conventional wisdom was 360 disc with 940T plate, but we've gone all-360 for now...will worry about slip as and when it happens!
