340 1.7 GL Performance Exhaust
afro_monkeys59
Post by afro_monkeys59 » 01 Jun 2005 03:00 am
I'm in need of an Ashley Performance exhaust system for my 340 in mild steel but have not found anywhere that supply these in the UK. If not Ashley Performance then anyone who knows anywhere i can obtain Performance exhaust systems for my car. I want a minimum of 4inch pollished tailpipe. Thank you for your help. Much appreciated.
Please email me at the folloeing address with any responce as i may not have internet access as of 8am on the 1st June 2005.
afro_monkeys59@hotmail.com
Steve.
bodejodel
Post by bodejodel » 01 Jun 2005 11:17 am
There is not much choice when searching for a 300 series exhaust.
I am going to modify a Remus rear silencer to fit my 360.
I could find no V300 performance exhausts at all here...
Jeroen
Ali
Post by Ali » 01 Jun 2005 03:01 pm
Don't think you'll find anything designed for the car but with a bit of work you'll be able to make things fit, started with a Peco backbox for a Ford Ka on mine (cut mounts off original backbox and welded them to peco box) and now got a 360 2L middlebox section on mine (1.4) makes it loud but making the larger bore middlebox fit the downpipe is a bit of a problem sm14 companies such as Tiger make stainless steel performance centre silencers (from demon tweeks about £40) and then you could make your own system (need some sections of straight pipe, 90, 45degree bends etc) but would be expensive to do and lots of joints where leaks could occur,
Ali
special
Post by special » 01 Jun 2005 06:52 pm
if your willing to spent the money there are plenty of places that will custom build one for you there are a few up my way (chesterfield mansfield sheffield way ) in fact theres a place called ascar at sheffield i hear there good
8)
dare to be different
