ny volvo 360 wont rev out ned help
drlove66
Post by drlove66 » 16 Jul 2014 05:27 am
my volvo 360 just wont rev out flat >>>> dont know why !!!! i place a b230f in it ...i try buying new Bosch WR7DC plugs place it in the engine got it too rev just few times ....i change even the plug wires and gas pump here vid let me kwn what you all think https://www.youtube.com/watch?v=Xxd5OWN ... e=youtu.be
volvomania
Re: ny volvo 360 wont rev out ned help
Post by volvomania » 16 Jul 2014 08:04 am
Can you write your text out in full??????? and proper English?
Then some of us might understand what you are on about and might be able to help. sm4
Post by classicswede » 16 Jul 2014 09:07 am
I would start by fitting the exhaust and air intake pipe.
Post by macplaxton » 16 Jul 2014 11:07 am
volvomania wrote:Can you write your text out in full??????? and proper English?
...Says the Belgian to the Jamaican... :lol: sm4
Here you go RJ:
My Volvo 360 engine will not rev up smoothly. Need help please.
Post by drlove66 » 16 Jul 2014 04:27
My Volvo 360 just won't rev up smoothly. I don't know why!!!! I have installed a B230F. I have bought a new set of Bosch WR7DC plugs and have fitted them. I got the engine to rev just a few times. I have also changed the HT leads and the fuel pump.
Here is a video:
http://www.youtube.com/watch?v=Xxd5OWNtJW0
Let me know what you all think.
Post by Ride_on » 16 Jul 2014 02:33 pm
You have not stated what you have checked, other than spark plugs and fuel pump, and you have a custome setup, you need to give more information. Have you checked for air leaks, is the fuel system suited to the engine? What car is the B230F from? Did it have carbs?
drlove66
Re: my volvo 360 wont rev out need help
Post by drlove66 » 17 Jul 2014 01:36 am
the engine come out of a :Volvo 240" type 1886 wagon the engine now it just say b230 dont know if its a b230f r b230e only the bottom half of the b230 block i place on my b200e head alone with the oil pump ,oil pan and wire loom. i check for air leaks there is "no air leaks" that i can see or ear .. some times when u rev it back fire out the in take and when it does rev it backs out the extake >>
360beast
Post by 360beast » 17 Jul 2014 07:56 am
Could it be possible LE can't handle the increased bore size... Or am I miles off.
Post by classicswede » 17 Jul 2014 09:00 am
OK so we now know that its a 360 GLT with a b230 bottom end so if everything is right it will run no problems.
First 2 things to check, are the HT leads in the correct order (plug leads) and is there any damage to the cap or rotor arm?
If that is all ok then most likely thing is that the timing belt is out by a tooth or two.
Post by Ride_on » 17 Jul 2014 08:35 pm
If it worked ok initially, did the belt slip because it was not correctly tensioned?
The GLT fuel system should be fine with the B230.
What about piston suitability? Compression ration, ignition advance? Are the pistons flat on top, are they the same height as the original? You might need to retard the ignition, which might be possible on some renix units.
drlove66
Post by drlove66 » 18 Jul 2014 03:57 pm
sorry i took so long ..... going too check all you guys ask bout today will respond too you later >>
