carb apart now, original floats weigh 10.9 grams rather than 6 - 6.3 grams... so massively wrong!
carb base plate seems to be warped by roughly .5mm in both directions as well. so i will take it into the garage in the morning to get it flattened, a big heavy ally block and wet and dry it is.
idle solenoid was loose and has a little dent in one side ? so going to test it on the 12v tomorrow and see.
i cant actually see anything else thats the matter with it, its all been doused in carb cleaner, wire wheeled all the bolts back to a nice standard and blew an airline through absolutely everything. almost ready to rebuild now.
i know that this is now quite far away from what the title says, but its all kind of relevant i guess!
1.7 B172 Fuel Layout Help
Re: 1.7 B172 Fuel Layout Help
1988 1.7 340 Redline
Here you go, but you probably know all this as the mac-worm has probably already told you.
LadbrokeOB wrote:carb apart now, original floats weigh 10.9 grams rather than 6 - 6.3 grams... so massively wrong!
mac wrote:I note you intend to rebuild the carb - I suggest you measure the weight of the float "fresh from the float chamber" it should weigh no more than 7g - if more, replace it. Genuine Solex floats are getting harder to find and are quite expensive but a good "tip" is to use a Lada Niva 1700 float - see e-bay link below.
http://www.ebay.co.uk/itm/321506934648c
You need a green block for bendy Z10s: viewtopic.php?f=6&t=14554 maybe a gasket: viewtopic.php?f=6&t=14874 and read here about crap dizzy caps: viewtopic.php?f=13&t=13778#p167504LadbrokeOB wrote:carb base plate seems to be warped by roughly .5mm in both directions as well.
Hi MAC,
please can you draw how the fuel System looks without the swirl pot?
In my 340 GL redline ist a fuel pump with three plugs. One is closed and the swirl pot.
My impression is that the swirl pot (boken since yesterday) can be removed an i can take the third plug from the pump for fuel return?
Best regards Matthias
Hi there Matthias,
With swill pot -
And without -
Hope the above helps - Mac
With swill pot -
And without -
Hello,
thanks MAC, for this help.
It works.
The new carb from a V440 I changed last year is compatible to the version without the swirl pot.
satisfied regards
Matthias
It works.
satisfied regards
Matthias
