Ignition types for 1.4 340s
Hi guys...
Was wondering if anyone could help with some info
340 1.4 breaker ignitions
Seems there are four types fitted but does anyone know what years they were used?
There is AC Delco, Ducellier, Bosch and SEV
SEV uses a casette points - only dwell angle can be adjusted.
AC Delco, Ducellier and Bosch use conventional breaker points
Im trying to compile a parts sharing list for volvo 66 and volvo 340 with other cars ( including ignition and brakes )
seems the AC Delco is shared with Opel and vauxhall models.
For cars with the Renix ignition... what type of distributor cap and rotor should be used??
Anyone know what years volvo used the different ignition systems?
Anyone know what other cars use these same parts?
cheers guys!
Shimon
cheers guys!
Shimon
Enjoy your 300s
I know one of the caps is common to a nova.
CI Rotor arm can be used for........
C.I ROTOR ARM TO FIT MODELS LISTED BELOW:
VOLVO 340 1.4 1979 - 1984 WITH DELCO DISTRIBUTOR (BLACK CAP)
VAUXHALL NOVA 1.0 1982 - 1992 WITH DELCO DISTRIBUTOR (BLACK CAP)
VAUXHALL ASTRA MK1 1.2 1980-1984 (WITH BLACK CAP)
VAUXHALL ASTRA MK1 1.3 1980-1982 (WITH BLACK CAP)
VAUXHALL ASTRA MK2 1.2 1984-1991 (WITH BLACK CAP)
Enjoy your 300s
Got this info so far.........
Lucas part number DCB 700 - condensor / capacitor and
Lucas part nuber DSB 700 Contact setfor use with
AC Delco distributor system
can be used for the following...............
Volvo
340 1.4 ( B14) 1979-1983
Vauxhall
Astra 1.2 1980-91
Astra 1.3 1980-1990
Cavalier 1600 1975-1981
Cavalier 1900 1975-1981
Cavalier 2000 1975-1981
Nova 1.0 OHV 1982>>
Opel
Admiral 2.8 1969-78
Admiral 2.8S 1972-76
Ascona A 1.2 1972-1975
Ascona A 1.6 1970-1975
Ascona A 1.9 1970-1975
Ascona B 1.2 1976-1979
Ascona B 1.3 1979-1982
Ascona B 1.6 1975-1981
Ascona B 1.9 1975-1981
Ascona B 2.0 1975-1981
Commodore B 2.5 1972-1978
Commodore B 2.8 1975-1978
Commodore C 2.5 1978-1981
Corsa 1.0 OHV 1982>>
Kadett 1.0 1973-1982
Kadett 1.1 1970-1973
Kadett 1.2 1970-1991
Kadett 1.3 1979-1984
Kadett 1.6 1978-1979
Kadett 1.9 1971-1973
Manta 1.2 1972-1979
Manta 1.6 1970-1981
Manta 1.9 1970-1981
Rekord 1.7 1972-1977
Rekord 1.9 1972-1977
Rekord 2.0 1972-1977
Volvo
Vauxhall
Astra 1.2 1980-91
Astra 1.3 1980-1990
Nova 1.0 OHV 1982>>
Opel
Admiral 2.8 1969-78
Manta 1.2 1972-1979
Manta 1.6 1970-1981
Manta 1.9 1970-1981
Enjoy your 300s
http://www2.qha.com/catalogues/ZC1-01.pdf
lists types of ignition for different years
useful for parts?
useful for parts?
Enjoy your 300s
AC Delco also used by......
A contact set, a rotor arm and a condenser to fit the following models with the AC DELCO ignition system
VAUXHALL
Astra 1200S (OHV) 80-84
Astra 1300S 80-82
Astra Mkll 1.2 (OHV) 84-91
Nova 1.0 83on
OPEL
Corsa 1.0 82-85
Kadett D 1.0 N, S; 1.2N, S 79-84
Kadett E 1.2 (OHV) 84-91
VOLVO
340; 343; 345 1.4 B14 79-84
Part nos.
Contacts Intermotor 22820
Rotor arm AC Delco 014-6142
Condenser CI XCON78
VAUXHALL
Astra 1300S 80-82
Nova 1.0 83on
OPEL
Corsa 1.0 82-85
VOLVO
Part nos.
Condenser CI XCON78
Enjoy your 300s
Quinton Hazel parts info
website www.qha.com
Volvo 66 info
Volvo 66
1.1 (4168A, 4245A distributors)
Contact set - XCS90
Condenser - XCON79
Cap - Don't do
Rotor - XR184
Ignition Coil - XIC8029
1.1 (4168B, 4245B distributors)
Same as above but :
Cap - XD140
1.3 (4502A distributor)
Contact set - XCS90
Condenser - XCON79
Cap - XD84
Rotor - XR71
1.3 (4502B distributor)
Same as above but :
Rotor - XR184
website www.qha.com
Volvo 66 info
Volvo 66
Contact set - XCS90
Condenser - XCON79
Cap - Don't do
Rotor - XR184
Same as above but :
Cap - XD140
Contact set - XCS90
Condenser - XCON79
Cap - XD84
Rotor - XR71
Same as above but :
Rotor - XR184
Enjoy your 300s
these are Quinton Hazel parts
Volvo 340 1.4 Delco 1979-1983
Contact set - XCS121
Condensor - XCON78
Distributor cap - XD82
Rotor arm - XR103
Ignition coil - XIC8029
Volvo 340 1.4 Ducellier 1976-1978
Contact set – XCS90
Condensor – XCON79
Distributor cap – XD314
Rotor arm – XR104
Ignition coil –XIC8029
Volvo 340 1.4 Ducellier 1978- 1983
Contact set – XCS90
Condensor – XCON79
Distributor cap –XD140
Rotor arm – XR104
Volvo 340 1.4 Ducellier 1983 onwards ( Renix )
Ignition module – XEI4
Condensor – N/A
Distributor cap – XD141
Rotor arm – XR160
Ignition coil –XIC 8076
Not sure why its lists ignition module and coil… unless module refers to the control unit mounted on the wing and ignition coil refers to the actual renix unit on the inner wing
Volvo 340 1.4 SEV 1979-1983
Contact set – XCS149
Condensor – XCON123
Distributor cap – XD125
Rotor arm – XR77
Ignition coil – XIC8029
Volvo 340 1.7 B172
Ignition module – XE14
Condensor – n/a
Distributor cap – XD158
Rotor arm – XR159
Ignition coil –XIC8076
Lists the ignition module and ignition coil as the same for a 1.4 and 1.7…. odd!
Condensor - XCON78
Rotor arm - XR103
Contact set – XCS90
Condensor – XCON79
Rotor arm – XR104
Contact set – XCS90
Condensor – XCON79
Rotor arm – XR104
Condensor – N/A
Rotor arm – XR160
Condensor – XCON123
Rotor arm – XR77
Volvo 340 1.7 B172
Condensor – n/a
Rotor arm – XR159
Enjoy your 300s
