K cam
Jimbean
K cam
Post by Jimbean » 25 Dec 2008 09:23 pm
Is this the b23e camshaft? its driving me nuts to get info on this :shock:
Hey kids grandpa's home! and he's coming in sideways!
Re: K cam
Post by jtbo » 26 Dec 2008 05:32 am
Jimbean wrote:Is this the b23e camshaft? its driving me nuts to get info on this :shock:
Volvo OE K grind- Used in high output, high compression b23e engines in Europe and Canada 81-83. Peak torque point was pushed to 4500 rpm. I sometimes have these for sale- US$59 plus US$20 mailing.
Specs and some other stuff:
http://www.geocities.com/iadr1/b21.23ca ... tml#jump22
H is better, bit more expensive and harder to come by as it was used only few years and only in GT if I remember correctly.
But if you would like to some power, pick something from here :lol: (prices in swedish currency, 1.00 SEK = 0.0846952 GBP so that is around 200 pounds from new hot cam, when used K ones are perhaps 100ish in UK/Europe?
http://www.kgtrimning.com/KGkamB2123.htm
Google translated version:
http://translate.google.com/translate?h ... l=sv&tl=en
Jimbean
Post by Jimbean » 26 Dec 2008 10:56 am
If you wernt in finland id fecking kiss you! :D
Jimbean
Post by Jimbean » 26 Dec 2008 11:31 am
Im freaking lost now lol! Just been reading on past posts and im confused to what engine i have?!
I always thought i had the red block B19 but someone said that it has a silver cam cover and mine is black in same post black one is B200?!
i have a 1988 360 2.0 GLT redblock But which code is it?
Post by trabitom99 » 26 Dec 2008 11:35 am
Hi Jim!
If your 360 is from '88 then you definitely have the B200. The B19 was dropped in '85 AFAIK.
Post by jtbo » 26 Dec 2008 11:46 am
trabitom99 wrote:Hi Jim!
That is true, B200E or B200F in Jimbean's car, depending from various things, typically I have seen B200F mostly with Cat and B200E mostly without Cat, but that is in Finland, I believe that different marketing areas had bit different combos with these.
E and F are with different engine management, which was which I can't really remember now.
Post by Chris_C » 26 Dec 2008 03:34 pm
We didn't get B200F's over here mate, 88 GLT will be a B200E. As it's a B200E what will you be doing about engine management Jimbean? Ali tried a different cam with LE-Jet and it didn't take to it too well.
Post by SteveP » 26 Dec 2008 03:57 pm
Ali tried a V cam, slightly hotter than the A cam - and it ran fine, Chris - but it didn't make any more power. I can't imagine a K cam taking too well to the standard engine management though - it'll probably make less power than stock.
His 3 door with the cam, air filter, exhaust was an exact match for my stock GLT saloon along a motorway sliproad from 30-70
Post by Chris_C » 26 Dec 2008 04:08 pm
Exactly, cam will be mismatched to the map. LH swap would be interesting though!
Jimbean
Post by Jimbean » 27 Dec 2008 10:30 am
will have to be megasuirt, perhaps if he tuned the cam to car he would made a increase
isnt the standard magement like semi mechanical as i have no rev limit?! i had a mk2 golf with total mechanical injection and that did have a rev limit k jet was the system.
Post by Chris_C » 27 Dec 2008 02:03 pm
Megasquirt will suit it well ;) Ali was only trying things out before he finally turbo'd and went with megasquirt.
LE is about the same level as K jet, but instead of the random mechincal injection (with the scary fuel dizzy ;)) it's done completely with passive electronics, RC values set the timings.
Jimbean
Post by Jimbean » 27 Dec 2008 09:37 pm
dam mechanical injection :evil:! Thanks for the info everybody! i no know that i dont have the engine i thought i had, and my cam idea sucks lol!
Tubby FTW!
Post by SteveP » 28 Dec 2008 10:52 am
LE-Jet on the 360 is actually electronic injection, but bases it's fuelling on stored values of a stock engine.
Best thing to do is megasquirt, it'll make even the standard car drive a million times better and feel far more perky/responsive
Post by classicswede » 01 Jan 2009 06:28 pm
Even the H cam is still quite tame. In a 2.1 tickover is still very nice with good low down pull.
Re: K cam
Post by foggyjames » 11 Jan 2009 03:13 am
I agree with Dai - anything less than a K, and you're not having fun! The transition 'onto cam' is far more pronounced and brutal in my factory spec S70 than in my 360 with a K cam.
