340 redblock conversion
340turbo
Re: 340 redblock conversion
Post by 340turbo » 27 Nov 2017 11:00 am
360 beast no longer needed but thank you!
340turbo
Post by 340turbo » 27 Nov 2017 11:01 am
360beast no longer need them but thank you!
340turbo
Post by 340turbo » 02 Dec 2017 01:22 am
today was a holiday..dont know what exactly but i had some spare time and made the engine mounts
they were tacked in place with the engine positioned and centered, then i removed the engine and subframe and welded them, also welded a nut to mount a cylindrical rubber mount...the mounts are rated for 300kg each so i think they will be strong enough...i used the original volvo 740 aluminium brackets on the engine.
340turbo
Post by 340turbo » 04 Dec 2017 03:06 pm
subframe is ready
subfram
and mounted
mounted
started closing the tunnel hole using the 740 tunnel. it is now tacked in place and i have to cut some side plates and do a massive welding job
tubbel
360beast
Post by 360beast » 04 Dec 2017 03:07 pm
Do you ever stop working on this? :lol:
Can you fly over to England and finish mine please? Next week okay for you? :lol:
340turbo
Post by 340turbo » 05 Dec 2017 12:31 am
360beast i think i am going too slow..i would work on it all day if i could but free time is very limited!
i would for sure help you on your volvos and i love England , the only thing better we have here is the weather :lol:
Post by Ride_on » 05 Dec 2017 02:01 am
I have some concerns on the ability for that cross beam to take the weight and torque of the red block. Volvo intertionally did not do it that way.
You are suporting the entire engine on 4x M8, and cantilevered. The 340 engine uses the cross beam, but also has rear supports.
The cross beam has a tendancy to crush at the end box sections if jacked in the middle.
The 360 engine is supported by 8 x M10 fine pitch.
I advise adding some support from the chassis leg to take the torque off the cross beam.
340turbo
Post by 340turbo » 08 Dec 2017 09:03 pm
hi...thanks for the advice, your concerns also passed through my mind when making the mounts
reason i used the crossmember as engine mounting point is i dont have acess to 360 parts and the mounts were awkward to fabricate from the engine directly to the chassis leg.
i reinforced heavily the box sections on the ends of the crossmember with 5mm bar
also the original screw holes have a reinforcing plate on the chassis leg with very long captive nuts and i will be replacing the original screws with stainless steel ones. but i might consider welding some tabs upwards and another bolting point just in case.
340turbo
Post by 340turbo » 08 Dec 2017 09:07 pm
today i spent 6 hours removing sound deadening from the passenger side and making progress on closing the tunnel
found a bunch of rotten spots and pinholes, the more i poke the more i find :roll:
340turbo
Post by 340turbo » 08 Dec 2017 09:12 pm
the transmission tunnel is huge so a good thing in the event of a (very distant i hope) future engine upgrade
i am planning on grinding the seams on the underside of the car and applying seam sealer and then something we call " anti-gravel"..it gives a rubberized and rough finish ... dont know the technical term in proper English....
i need advice on something to apply on the inside to act as sound deadening and add some cushioning before the carpets...something cheap if possible...
Post by classicswede » 21 Apr 2018 09:53 pm
How are you getting on with this?
RussianFartParty
Post by RussianFartParty » 09 May 2020 01:30 am
I too would like to know how this went!!!
fatuglypaapa1
Post by fatuglypaapa1 » 08 May 2022 09:05 pm
This looks great, I myself am thinking of converting the engine myself in the future. I at least want to change out the gearbox and put it up front rather than the back and get a new axle.
