Yeah, its nothing much to worry about, but yes, possibly mild gasket leak there.
And on the other subject, lol...
foggyjames wrote:A welded diff might help there, but if one wheel is spinning, the other can't be far behind.
Other wheel will be far behind! Hence why you see so many cars with open diffs doing 1 wheel burnouts with the other wheel totally static, you can put 100% of the power to one wheel on an open one, thats how they work.
They safe, but shite.
Trust me when I say the difference between an open diff with regards to traction at the dragstrip, if you actually have any power, is huge.
Been there, tested that.
Hard suspension and a welder makes a quicker drag car than softer (ie better for dragging in many respects, not in all though, you want the wheel pushed into the ground, not the suspension taking up all the squat) suspension and an open diff, thats for sure.
But yes, depending on the type of sport your doing, mods you do may do well for that sport, but less so for another.
Still a damn sight better than standard though!
And i was merely stating that they are set up in almost the same way as a circuit car, and would be better than standard regardless.
