high rpm......bad?
spike4073
Re: high rpm......bad?
Post by spike4073 » 27 Sep 2011 07:41 pm
anybody??
Post by volvodspec » 28 Sep 2011 06:18 pm
yes it does, now check resistance at terminal 6. if it's infinite then there's something wrong with the brake sensor/kickdown sensor/low gear hold switch and if you get 0Ω then the tacho relay is broken/stuck.
spike4073
Post by spike4073 » 28 Sep 2011 08:00 pm
ok thanks.... im crap with a multimeter..... where do i stick the pins when checking resistance??? ..... ive only ever used one to check voltage :S
