Is it worth fixing?
Is it worth fixing?
Hi Grendel
Depends what you mean by economically viable really. If you mean would it cost more for a mechanic to repair than the value of the car then the answer would probably be yes (£400 would be hopeful!).
Fixing it yourself however makes it a much more viable proposition esp. if you use parts from a scrap car. Even for the most cack handed mechanic, a new manifold should not be too much of a problem. Even if you have to buy a socket set it should be very cheap to do and will give you a sense of satisfaction at being a little less reliant on expensive garages.
Maybe one of our members round your way would be able to help...
If the car is running OK, the carb isn`t likely to be too bad and will probably soldier on for a while.
BTW 250K for a 1.4 is pretty good going
Will
Will
I'll give help if I can (have got my project due in soon, but can work around that). Have socket set etc, is it just a filter, carb, old one off, new one on effort Will? And gaskets from Volvo?
Theres a few good scrappies around too, so the 'new' one should be too hard to get.
Presumably the cracked manifold is the exhaust manifold?
150k is still good going! My 340 project car, Nessy (aka: the one Hugh didn't crash), has 182k on the clock, and I'm trying to get her to 200k on the original engine (before it gets removed and replaced with something downright gratuitous). I've got a devious plan for achieving 200k (he says with an evil grin) which is slowly formulating....let's just say we might see another female V3Mmer if all goes according to plan
You have too many devious plans! I thought this might've involved a rolling road and a brickfoggyjames wrote:I've got a devious plan for achieving 200k (he says with an evil grin) which is slowly formulating....let's just say we might see another female V3Mmer if all goes according to plan
" is it just a filter, carb, old one off, new one on effort Will"
That`s about the size of it. Start putting penetrating oil on the nuts a few days beforehand. Probably a good idea to have some spares.
Some of them are a complete PITA to reach, so it`s worth taking out the washer reservoir.
Tighten manifold to head first, manifold to downpipe second then pipe to clutch housing last.
Enjoy
Will
Enjoy
Will
Haha...about the intelligence of a brick... (ducks punch from the lady of the house). She's gotta learn how to drive first...and I gotta make Nessy roadworthy! We'll see....it's only a plan at this stage.SteveP wrote:I thought this might've involved a rolling road and a brick
You've not met her, have you............?petefarrell360 wrote:Both cunning plans there chaps, how about combining the two, let her learn to drive on the rolling road! Now in theory the risk of crashing is greatly reduced!
Just a thought but how much do you want for the 1.4 340 manifold and could you post it to Southampton?daffodil wrote:hi i have spare manifolds its not a long job to change its 1 or 2 hours max if you need any parts you can e-mail me
many thanks martin
All I should need to fit it will be a exhaust manifold gasket and gasket sealant cream from Halfords I presume?
Yep, second that, the manifold to downpipe nuts are a complete PITA. They're good quality nuts so they don't really seize on, but they're just extremely difficult to get at. TBH I don't remember how we got at them. I do remember having to take the manifold off with the exhaust still attached and then getting at the nuts afterwards with the manifold half on half off the car! The others should all be reasonably easy.wjp01908 wrote:" is it just a filter, carb, old one off, new one on effort Will"
Enjoy
Will
Andy
