Air Flow meter for 360GLT B200E
kelvingenders
Post by kelvingenders » 26 Jan 2011 11:56 am
Does anyone know if there are Bosch Le Jetronic equivalents from the the 240/740/940 range that would fit into a 360GLT B200E. Can you buy them brand new still in the UK?
Re: Air Flow meter for 360GLT B200E
Post by pettaw » 27 Jan 2011 04:37 pm
Unfortunately the 2/7/9 series don't use LE-jet, and I'm pretty sure they went from K-jet which is a mechanical system, straight through to Motronic which uses a mass air flow sensor rather than the flappy paddle meter in the 360.
I've no idea whether they're still available, certainly Volvo don't have them, but might Bosch still sell them? Very doubtful....
Whilst being very basic they don't go wrong very often. Can I ask why you need one?
kelvingenders
Post by kelvingenders » 27 Jan 2011 04:55 pm
It idles like a dog... and noticed some has repaired it with silicon at the top....cannot be doing the system very good :360: sm1 !!
Post by Chris_C » 27 Jan 2011 07:01 pm
Green book lists the resistances of the tracks, it's worth looking at... (gets thinking cap on) mk1 vauxhall cavielers (only better spelt ones though), Porsche 914 ish, VW type 4's, and I think... e30 318's. I'm pretty certain all ran either L or LE jet (likely some more too) and I can't imagine the flappy thing was changed much but you'll have to do the research.
Certainly the AMM on clios/R19/Megane/espace/440/850/Nova/Corsa/a squillion and 10 other things are all the same, I can't imagine Bosch would invent more things than required.
Post by Chris_C » 27 Jan 2011 07:05 pm
This is a fairly comprihensive list of what part fits on what car...
http://www.stonis-world.net/docs/bosch_ ... ations.pdf
Should give you a list of LE/L jet cars and what flappy paddle's they run at least
kelvingenders
Post by kelvingenders » 27 Jan 2011 07:18 pm
What do you mean by flappy paddle
Kelvin
kelvingenders
Post by kelvingenders » 27 Jan 2011 07:39 pm
Looks like a BMW will be the most suitable....better get my cheque book
Post by Chris_C » 27 Jan 2011 08:19 pm
Air flow meter, if you have a look inside, the only thing that measures the air going past is a paddle that flaps in the wind
kelvingenders
Post by kelvingenders » 28 Jan 2011 12:00 am
Looks like the BMW run a different pin connection.D'oh
valdemaras
Post by valdemaras » 28 Jan 2011 12:04 pm
kelvingenders wrote:Looks like the BMW run a different pin connection.D'oh
they had two types of connections the older 3rd series had the same as volvo i think models till 1989, i had from `88 with 1.8l and it fit perfectly ;)
also as i had made some search when i was looking for meter for myself i found that from old 5 series (E28 i think) with a 2.0l V6 the meter should fit in to volvo,
but those bmw are rear thing in eastern europe, don`t know about down under :)
'86 340 1.4 sold
'92 Mitsubishi Lancer 1.3 sold
'92 Mitsubishi Lancer 1.6 scraped
'86 360 GLT 2.0i
