Page 1 of 2
F7P Wiring
Posted: 30 Aug 2011 03:24 pm
by billkent22
Hello,
Firstly I want to appologise if i sound thick in anyway or if this is a re-post!
I have a few questions relating to the wiring loom part of the F7P conversion into my 340
I am not using Adams plug and play loom btw as i want to have a go at this myself and anyway how hard can it be, right
? lol
From what i have seen while searching on the site people remove all the wiring not used, again appoligise if this sounds stupid but i was going to plug it all in as it is and whatever i dont use either leave it and tape it up or cut it off. Other than the fuel pump and a few other bits that would have to be spliced in?
Bill
Re: F7P Wiring
Posted: 02 Sep 2011 04:28 pm
by billkent22
Got the engine in today!
So next step is the wiring. I just need to try and find what wire is for what on the ranult loom and then find out what parts of the volvo loom i need to cut into, there dosent really seem to be much volvo loom tho!?
Bill
Re: F7P Wiring
Posted: 03 Sep 2011 08:36 am
You pretty much need most of the F7P loom, all sensors etc. Connecting it to the Volvo loom required things like power, ignition, ground, rev counter, oil light etc. The F7P coil goes onto the old Renix plugs
Re: F7P Wiring
Posted: 03 Sep 2011 10:44 am
by billkent22
O ok, you make it sound very easy! lol
There isnt many volvo wire in the engine bay anyway to be honest, just gotta find out whats what now!
Re: F7P Wiring
Posted: 03 Sep 2011 07:05 pm
It's not horrible, best thing to do is lay it on top of the engine (well, when the engine is out it's even easier
Plug everything in, then you can work out what the other wires do.
www.retro-renault.com have a good F7P ECU plug pinout
Re: F7P Wiring
Posted: 04 Sep 2011 07:15 pm
by billkent22
Thank you for your help mate, that pin-out was very helpful!
Ive started removing what i know i wont need and labeling up what plug is for what BUT i am stuck again lol
What are these plugs/wires for!?
Re: F7P Wiring
Posted: 04 Sep 2011 09:40 pm
Black plug seems to be where the loom connects to the car, i.e power in, oil pressure and rev counter out... I *think*. They certainly arn't present in my loom, but it was a while ago I made mine!
Re: F7P Wiring
Posted: 05 Sep 2011 03:59 pm
by billkent22
Im guessing from that plug im taking the
red(Live) yellow(ignition?) and white(which seems to bea earth?!)
And tapping into the volvo loom to find the relevant ones, however i dont know how many relays i need or what each one is for!? Bloody nightmare seeing as there is just NO diagrams online (ive spent hours looking)!
Re: F7P Wiring
Posted: 07 Sep 2011 09:51 pm
by billkent22
Right ive gone and chopped the loom to bits to get only what i need sorted!
Ive plugged in all the plugs into the sensors and just have wires to soulder back up to the main ECU multiplug.
Just wanna check a few things:
I only have ONE 3 pin plug plugged into the renix atm, is that right?
I assume i plug the volvo wiring into the Volvo water temp sender that removed from the old lump?
I have worked it out that i have TWO relays; Fuel pump and ECU is this right (i have used both brown ones)??
Also i take it the realys have their own power source (live,ign and earth?) which i get direct from the volvo loom which runs along the bulkhead and past the wiper motor.
Bill
I really appreciate peoples help on here btw,
Thank you!
Re: F7P Wiring
Posted: 07 Sep 2011 10:10 pm
billkent22 wrote:I only have ONE 3 pin plug plugged into the renix atm, is that right?One 3pin plug and one 2 pin plug with one wire in it into the valver coil pack, not the old 300 renix
I assume i plug the volvo wiring into the Volvo water temp sender that removed from the old lump?Yes
I have worked it out that i have TWO relays; Fuel pump and ECU is this right (i have used both brown ones)?? Think so, I certainly have 2 and from memory it is those
Also i take it the realys have their own power source (live,ign and earth?) which i get direct from the volvo loom which runs along the bulkhead and past the wiper motor.Almost! There is a switched ignition to the ECU and then the ECU fires the fuel pump relay. Can't remember what fires the other relay off hand though, so maybe my answer to (3) is wrong...
Re: F7P Wiring
Posted: 08 Sep 2011 02:32 pm
by billkent22
Chris_C wrote:billkent22 wrote:I only have ONE 3 pin plug plugged into the renix atm, is that right?One 3pin plug and one 2 pin plug with one wire in it into the valver coil pack, not the old 300 renix
I dont have a coil pack ive got dizzy, does this mean i ignore the 2 pin plug with one wire, if not what is that wire for!?
Bill
Re: F7P Wiring
Posted: 08 Sep 2011 03:20 pm
I'm calling the thing that looks a bit like a Renix, but doesn't have vacuum feed, a coil pack. With a dizzy you still need this bit. The difference between it and the Renix is the renix is a self contained ECU, the coil pack is a slave triggered by the F7x ECU.
The single wire in 2pin plug is erm.. I forget now
Brown and black stripey...
Re: F7P Wiring
Posted: 08 Sep 2011 04:02 pm
by billkent22
Chris_C wrote:I'm calling the thing that looks a bit like a Renix, but doesn't have vacuum feed, a coil pack. With a dizzy you still need this bit. The difference between it and the Renix is the renix is a self contained ECU, the coil pack is a slave triggered by the F7x ECU.
oooo is this the little box thats bolted to the N/S wing infront of the wiper motor?
Bill (Sorry i know im being thick but im learing!)
Re: F7P Wiring
Posted: 08 Sep 2011 06:55 pm
by Alex Laidlaw
No I that is nothing to do with the engine, I think it is something to do with the wipers. The coil pack thing looks just like a 1.4/1.7 Renix but doesn't have the vacuum connection on the bottom of it. It has three plugs which look outwardly the same as the Renix but have different connections. The Renault coil pack will bolt has the same hole pattern as the Renix and would bolt onto the same place on the NS chassis rail if the inlet manifold wasn't in the way.
Re: F7P Wiring
Posted: 08 Sep 2011 08:59 pm
by billkent22
AHHHHH i dont have that! thats why i dont know what your on about!
I assme thats a clio/ ren 19 item?! Although its not mentioned in any of the conversion posts on here or anywhere else?
Bill
Will this do the job -
http://www.eurocarparts.com/ecp/c/Renau ... c2f&000197
Despite the bloody price
