Gearbox help/advice needed
Post by Speedy88 » 25 Feb 2012 08:29 pm
Hi guys,
I wasn't able to get hold on a 360 gearbox in time so a crazy part of my brain told me that the input shafts would be the same on the 340 and 360 5 speeds. However, looking at the differences in the shaft lengths and spline pattern, the differences are quite apparent:
340
360
Ok, so I have 2 questions:
1) Can I swap over the input shafts? - I don't think this is an option as the front gearbox mount is going to be in the way of the 360 front plate.
2) Can I swap over the internals?
Re: Gearbox help/advice needed
Post by volvodspec » 25 Feb 2012 08:38 pm
i haven't pshysically executed it, but i think that you can swap over the input shafts along with the front cover
recently took a gearbox apart to replace the synchro's
the front cover simply bolts over and the input shaft is easaly removed via a cirlip
Post by Speedy88 » 25 Feb 2012 08:51 pm
Ah excellent, external circlip?
