i've broken the cunningly shat plastic part of the breather pipe that connects the head to the carb...
any ideas of a fix? tape doesn't work...
chemical metal probably wouldn't work either cause its too greasy.
does the pipe come out easily? if so i can get a replacement from the local scrape yard.
oil breather pipe
oil breather pipe
Is the car a 1.4?
Do you meanthe plastic T shape piece that fits into the rocker cover / top of engine?
It connects to the carb via the second arm via a rubber hose and to the airfilter via the third arm via a shorter rubber hose ( goes into base of air filter)
I have broken these before. Use pliers to remove the broken bits from the top of the rocker cover - the piece left behind should just lift out.
New T pieces are a few quid from volvo or you could go to a scrappy ang get one off a car there....
Shimon
Shimon
Enjoy your 300s
